"DuplicateFile" method fails with "Operation not supported"
nevi
Hello
I am using the .NET assembly of WinSCP 5.13.1 (Build 8265) from PowerShell on Windows 10.
I have followed the good and detailed descriptions in the WinSCP web site for using the assembly in PowerShell. But unfortunately, the DuplicateFile method is generating an exception, when I try to call it. More specifically, I get the following error message:
Exception calling "DuplicateFile" with "2" argument(s): "Operation not supported."
I specified a session log file in my script, from where I see a similar entry:
> 2018-05-16 15:47:29.008 Script: cp "/remote/folder1/File2.txt" "/remote/folder1/Backup/"
< 2018-05-16 15:47:29.011 Script: Operation not supported.
I have no problems downloading the file, then uploading it to the destination folder. But I would really like to avoid this.
For the record, I also have no problem using the MoveFile method on the same file and folders.
Please advise.
Best regards,
Neilsean Lavlund Victorino
Re: "DuplicateFile" method fails
What protocol are you using?
nevi
Hello
Thank you for the quick response.
I am using the FTP protocol, which can be seen in the attached session log file.
best regards
  • Log.txt (6.66 KB, Private file)
Description: The acoount, file and folder names and ip addresses in the log files are anonymized.
That explains it all!
I wasn't aware of that prerequisite.
Thank you very much for your help!
best regards
