"Command not implemented for that parameter" when i try to create a new directory, version 5.13.2
jmar83
Hi there!
Firstly, i was thinking that problem will be solved with that version. But i was wrong...
The OS i use (both sides client and server) is Windows Server 2003 32 But, Web Edition, SP2 & all Updates installed. (And 2-3 hotfixes)
When i connect to the FTP service, provided by FileZilla FTP Server, i get that message:
"Command not implemented for that parameter".
But the diectory will be created, beause of that in my opinion it's a message without any sense. I think you can easily suppress it on that case!
I can send you some client- and server logs if you want, that's no problem.
With best regards,
Jan
Description: Screenshot
Re: "Command not implemented for that parameter" when i try to create a new directory, version 5.13.2
Yes, please attach log files.
jmar83
i renamed the directories for the 2 domains i host, because they contains the domain names. and i also renamed the ip to 0.0.0.0:
. 2018-05-17 09:52:24.696 Session upkeep
. 2018-05-17 09:52:24.903 Session upkeep
. 2018-05-17 09:52:25.393 Session upkeep
. 2018-05-17 09:52:25.883 Session upkeep
. 2018-05-17 09:52:26.373 Session upkeep
. 2018-05-17 09:52:26.863 Session upkeep
. 2018-05-17 09:52:27.353 Session upkeep
. 2018-05-17 09:52:27.843 Session upkeep
. 2018-05-17 09:52:28.333 Session upkeep
. 2018-05-17 09:52:28.824 Session upkeep
. 2018-05-17 09:52:29.314 Session upkeep
. 2018-05-17 09:52:29.804 Session upkeep
. 2018-05-17 09:52:30.309 Session upkeep
. 2018-05-17 09:52:30.799 Session upkeep
. 2018-05-17 09:52:31.289 Session upkeep
. 2018-05-17 09:52:31.779 Session upkeep
. 2018-05-17 09:52:32.269 Session upkeep
. 2018-05-17 09:52:32.759 Session upkeep
. 2018-05-17 09:52:33.249 Session upkeep
. 2018-05-17 09:52:33.739 Session upkeep
. 2018-05-17 09:52:33.893 Creating directory "Neuer Ordner".
> 2018-05-17 09:52:33.893 CWD /
< 2018-05-17 09:52:33.923 250 CWD successful. "/" is current directory.
> 2018-05-17 09:52:33.923 MKD Neuer Ordner
< 2018-05-17 09:52:33.938 257 "/Neuer Ordner" created successfully
. 2018-05-17 09:52:33.938 Got reply 1 to the command 256
. 2018-05-17 09:52:33.938 Rufe Dateiinformationen ab...
> 2018-05-17 09:52:33.938 MLST /Neuer Ordner
< 2018-05-17 09:52:33.969 250-Listing /Neuer Ordner
< 2018-05-17 09:52:33.969 type=dir;modify=20180517075236; /Neuer Ordner
< 2018-05-17 09:52:33.969 250 End
. 2018-05-17 09:52:33.969 type=dir;modify=20180517075236; /Neuer Ordner
. 2018-05-17 09:52:33.969 Dateiinformationen erfolgreich angerufen
. 2018-05-17 09:52:33.969 Got reply 1 to the command 1024
> 2018-05-17 09:52:33.969 SITE CHMOD 755 /Neuer Ordner
< 2018-05-17 09:52:34.000 504 Command not implemented for that parameter
. 2018-05-17 09:52:34.000 Got reply 4 to the command 512
. 2018-05-17 09:52:34.000 Asking user:
. 2018-05-17 09:52:34.000 Kann die Eigenschaften der Datei 'Neuer Ordner' nicht ändern. ("Command not implemented for that parameter")
. 2018-05-17 09:52:34.229 Session upkeep
. 2018-05-17 09:52:34.735 Session upkeep
. 2018-05-17 09:52:35.274 Session upkeep
. 2018-05-17 09:52:35.813 Session upkeep
. 2018-05-17 09:52:36.352 Session upkeep
. 2018-05-17 09:52:36.891 Session upkeep
. 2018-05-17 09:52:37.262 Rufe Verzeichnisinhalt ab...
> 2018-05-17 09:52:37.262 TYPE A
< 2018-05-17 09:52:37.278 200 Type set to A
> 2018-05-17 09:52:37.278 PASV
< 2018-05-17 09:52:37.312 227 Entering Passive Mode (0.0.0.0,4,80)
> 2018-05-17 09:52:37.312 MLSD
. 2018-05-17 09:52:37.312 Verbinde mit 0.0.0.0:1104 ...
< 2018-05-17 09:52:37.363 150 Opening data channel for directory listing of "/"
< 2018-05-17 09:52:37.363 226 Successfully transferred "/"
. 2018-05-17 09:52:37.363 Data connection closed
. 2018-05-17 09:52:37.363 type=dir;modify=20180517075236; Neuer Ordner
. 2018-05-17 09:52:37.363 type=dir;modify=20180515013539; my_site1
. 2018-05-17 09:52:37.363 type=dir;modify=20180509032811; my_site2
. 2018-05-17 09:52:37.363 Verzeichnisinhalt erfolgreich abgerufen
. 2018-05-17 09:52:37.363 Got reply 1 to the command 2
. 2018-05-17 09:52:37.363 ..;D;0;1899-12-30T02:00:00.000Z;0;"" [0];"" [0];---------;0
. 2018-05-17 09:52:37.363 Neuer Ordner;D;0;2018-05-17T07:52:36.000Z;3;"" [0];"" [0];---------;0
. 2018-05-17 09:52:37.363 my_site1;D;0;2018-05-15T01:35:39.000Z;3;"" [0];"" [0];---------;0
. 2018-05-17 09:52:37.363 my_site2;D;0;2018-05-09T03:28:11.000Z;3;"" [0];"" [0];---------;0
. 2018-05-17 09:52:37.380 Session upkeep
. 2018-05-17 09:52:37.430 Session upkeep
. 2018-05-17 09:52:37.969 Session upkeep
. 2018-05-17 09:52:38.508 Session upkeep
. 2018-05-17 09:52:39.047 Session upkeep
. 2018-05-17 09:52:39.586 Session upkeep
. 2018-05-17 09:52:39.788 Getting current directory name.
. 2018-05-17 09:52:39.788 Rufe Verzeichnisinhalt ab...
> 2018-05-17 09:52:39.788 TYPE A
< 2018-05-17 09:52:39.822 200 Type set to A
> 2018-05-17 09:52:39.822 PASV
< 2018-05-17 09:52:39.839 227 Entering Passive Mode (0.0.0.0,4,81)
> 2018-05-17 09:52:39.839 MLSD
. 2018-05-17 09:52:39.839 Verbinde mit 0.0.0.0:1105 ...
< 2018-05-17 09:52:39.890 150 Opening data channel for directory listing of "/"
< 2018-05-17 09:52:39.890 226 Successfully transferred "/"
. 2018-05-17 09:52:39.890 Data connection closed
. 2018-05-17 09:52:39.890 type=dir;modify=20180517075236; Neuer Ordner
. 2018-05-17 09:52:39.890 type=dir;modify=20180515013539; my_site1
. 2018-05-17 09:52:39.890 type=dir;modify=20180509032811; my_site2
. 2018-05-17 09:52:39.890 Verzeichnisinhalt erfolgreich abgerufen
. 2018-05-17 09:52:39.890 Got reply 1 to the command 2
. 2018-05-17 09:52:39.890 ..;D;0;1899-12-30T02:00:00.000Z;0;"" [0];"" [0];---------;0
. 2018-05-17 09:52:39.890 Neuer Ordner;D;0;2018-05-17T07:52:36.000Z;3;"" [0];"" [0];---------;0
. 2018-05-17 09:52:39.890 my_site1;D;0;2018-05-15T01:35:39.000Z;3;"" [0];"" [0];---------;0
. 2018-05-17 09:52:39.890 my_site2;D;0;2018-05-09T03:28:11.000Z;3;"" [0];"" [0];---------;0
. 2018-05-17 09:52:39.890 Session upkeep
. 2018-05-17 09:52:40.125 Session upkeep
. 2018-05-17 09:52:40.260 Getting current directory name.
. 2018-05-17 09:52:40.260 Rufe Verzeichnisinhalt ab...
> 2018-05-17 09:52:40.260 TYPE A
< 2018-05-17 09:52:40.277 200 Type set to A
> 2018-05-17 09:52:40.277 PASV
< 2018-05-17 09:52:40.311 227 Entering Passive Mode (0.0.0.0,4,82)
> 2018-05-17 09:52:40.311 MLSD
. 2018-05-17 09:52:40.311 Verbinde mit 0.0.0.0:1106 ...
< 2018-05-17 09:52:40.361 150 Opening data channel for directory listing of "/"
< 2018-05-17 09:52:40.361 226 Successfully transferred "/"
. 2018-05-17 09:52:40.361 Data connection closed
. 2018-05-17 09:52:40.361 type=dir;modify=20180517075236; Neuer Ordner
. 2018-05-17 09:52:40.361 type=dir;modify=20180515013539; my_site1
. 2018-05-17 09:52:40.361 type=dir;modify=20180509032811; my_site2
. 2018-05-17 09:52:40.361 Verzeichnisinhalt erfolgreich abgerufen
. 2018-05-17 09:52:40.361 Got reply 1 to the command 2
. 2018-05-17 09:52:40.361 ..;D;0;1899-12-30T02:00:00.000Z;0;"" [0];"" [0];---------;0
. 2018-05-17 09:52:40.361 Neuer Ordner;D;0;2018-05-17T07:52:36.000Z;3;"" [0];"" [0];---------;0
. 2018-05-17 09:52:40.361 my_site1;D;0;2018-05-15T01:35:39.000Z;3;"" [0];"" [0];---------;0
. 2018-05-17 09:52:40.361 my_site2;D;0;2018-05-09T03:28:11.000Z;3;"" [0];"" [0];---------;0
. 2018-05-17 09:52:40.378 Session upkeep
. 2018-05-17 09:52:40.664 Session upkeep
. 2018-05-17 09:52:41.204 Session upkeep
. 2018-05-17 09:52:41.743 Session upkeep
. 2018-05-17 09:52:42.282 Session upkeep
. 2018-05-17 09:52:42.821 Session upkeep
. 2018-05-17 09:52:43.360 Session upkeep
. 2018-05-17 09:52:43.899 Session upkeep
. 2018-05-17 09:52:44.438 Session upkeep
. 2018-05-17 09:52:44.977 Session upkeep
. 2018-05-17 09:52:45.504 Session upkeep
. 2018-05-17 09:52:46.004 Session upkeep
. 2018-05-17 09:52:46.504 Session upkeep
. 2018-05-17 09:52:47.004 Session upkeep
. 2018-05-17 09:52:47.504 Session upkeep
. 2018-05-17 09:52:48.004 Session upkeep
. 2018-05-17 09:52:48.504 Session upkeep
. 2018-05-17 09:52:49.004 Session upkeep
. 2018-05-17 09:52:49.504 Session upkeep
. 2018-05-17 09:52:50.004 Session upkeep
. 2018-05-17 09:52:50.504 Session upkeep
. 2018-05-17 09:52:51.004 Session upkeep
. 2018-05-17 09:52:51.504 Session upkeep
. 2018-05-17 09:52:52.004 Session upkeep
. 2018-05-17 09:52:52.504 Session upkeep
. 2018-05-17 09:52:53.004 Session upkeep
. 2018-05-17 09:52:53.519 Session upkeep
. 2018-05-17 09:52:54.019 Session upkeep
. 2018-05-17 09:52:54.519 Session upkeep
. 2018-05-17 09:52:55.019 Session upkeep
. 2018-05-17 09:52:55.519 Session upkeep
. 2018-05-17 09:52:56.019 Session upkeep
. 2018-05-17 09:52:56.519 Session upkeep
. 2018-05-17 09:52:57.019 Session upkeep
. 2018-05-17 09:52:57.519 Session upkeep
. 2018-05-17 09:52:58.019 Session upkeep
. 2018-05-17 09:52:58.519 Session upkeep
. 2018-05-17 09:52:59.019 Session upkeep
. 2018-05-17 09:52:59.519 Session upkeep
. 2018-05-17 09:53:00.019 Session upkeep
. 2018-05-17 09:53:00.519 Session upkeep
. 2018-05-17 09:53:01.019 Session upkeep
. 2018-05-17 09:53:01.191 Session upkeep
. 2018-05-17 09:53:01.519 Session upkeep
. 2018-05-17 09:53:02.019 Session upkeep
. 2018-05-17 09:53:02.519 Session upkeep
. 2018-05-17 09:53:03.019 Session upkeep
. 2018-05-17 09:53:03.519 Session upkeep
. 2018-05-17 09:53:04.019 Session upkeep
. 2018-05-17 09:53:04.519 Session upkeep
. 2018-05-17 09:53:05.019 Session upkeep
. 2018-05-17 09:53:05.519 Session upkeep
. 2018-05-17 09:53:06.019 Session upkeep
. 2018-05-17 09:53:06.519 Session upkeep
. 2018-05-17 09:53:07.019 Session upkeep
. 2018-05-17 09:53:07.519 Session upkeep
. 2018-05-17 09:53:08.019 Session upkeep
. 2018-05-17 09:53:08.519 Session upkeep
. 2018-05-17 09:53:09.019 Session upkeep
. 2018-05-17 09:53:09.519 Session upkeep
It tries to set file/directory permission attribute on a windows server, that does not work! ;)
Maybe FileZilla Webserver does not transmit the information on which OS it runs, so there is no solution for that issue..?
Regards,
Jan
