Wait till PUT is completed
LaurentzT
I use this code to upload a document, starting from a cmd.exe:
\\...SFTP\WinSCP.com "/command" "open sftp://USER:PASS@ftpedi.group.com/home/COMPANY/DATA/IN/" "put \\...\B98_VERBAU_____WMS-VIO____1419.DFD"
When I start it like this, it works and the file gets uploaden. But when I call a exit after the PUT, the program does't wait till the file is uploaded and exit the cmd to early...
Any tips or tricks for it?
Re: Wait till PUT is completed
LaurentzT
I tried it with the latest version but it is still the same.
Can you help me with the command because I can't get it to work with the logging if I shell execute it:
\\path\SFTP\WinSCP.com "/command" "open sftp://user:pass@ftpedi-group.com/home/VER/DATA/ /log=C:\log.log" "put \\ver.be\workspace\Prog\Firmware\TransportShipmentEDI\\B98_VERBAU_____WMS-VUO____9884.DFD"
The /log switch must be outside of the script commands:
\\path\SFTP\WinSCP.com /log=C:\log.log "/command" "open sftp://user:pass@ftpedi-group.com/home/VER/DATA/" "put \\ver.be\workspace\Prog\Firmware\TransportShipmentEDI\\B98_VERBAU_____WMS-VUO____9884.DFD"
