winscp.com synchronize resumesupport=on is not copying to a temporary file, and not resuming
JohnA
New Zealand
winscp.com synchronize resumesupport=on is not storing the file being transferred to a temporary filename first.
Resource monitor shows that winscp is writing to the target filename, not a temporary file.
If I interrupt and resume the synchronisation, it starts the copy from 0%.
Details:
Windows Server 2016
winscp.com v5.13
Connection details, from winscp.ini, (TLS/SSL Explicit encryption):
[Sessions\backup.worryfree.co.nz]
HostName=pmrrep.advantage.co.nz
PortNumber=21
FSProtocol=5
Ftps=3
Command (from PowerShell session):
winscp.com -command 'open "backup.worryfree.co.nz"' 'synchronize local "U:\backups\ShadowProtect\gls2-check\test" "/gls2/test" -resumesupport=on -criteria=size' -log='resumeSupport.log'
I get the same behaviour with:
winscp.com /script=S:\temp\winscp.script
and S:\temp\winscp.script:
option echo on
JohnA
Thanks Martin.
Could winscp be enhanced to allow copying to a temporary file for all FTP protocols, even if resume support is not supported by the protocol?
