Files with special characters (like registered trademark) not displaying on winscp command line
jbrione3
When handling files with special characters in the filename, in this case the registered trademark, the files do not display in the winscp command line with 'ls'. To illustrate this problem, simply create a file like "test®.txt" and upload to remote directory. The file is almost "hidden" because of the special character. I read through the entire FAQ on special characters but my problem persists. Any help is appreciated. Thank you.
Re: Files with special characters (like registered trademark) not displaying on winscp command line
