exit command at the end of winscp.com command closes all windows and the batch script cannot continu
ger_serrano@...
I have this command in a batch script:
/log="X:\cme\ftp_files\DailyLog\WinSCP.log" /ini=nul ^
/command ^
"open sftp://acoscftp:""@NLJl!xS<mqq""@sftpng.cmegroup.com/ -hostkey=""ssh-rsa 2048 jnrVgUsNrZ+VmunhM0XrnWnlc2gVhSBOK+jFx5vQoMc=""" ^
"cd Outgoing" ^
"get -filemask=""CME*.zip>=5D"" -transfer=binary /cme/ftp/OSC/Outgoing x:\CME\ftp_files\Download" ^
"exit"
But the "exit" terminates completely the script. As a workaround I created two scripts one with the winscp commnad and then another one that exec utes after the winscp finishes.
Is there another way of terminating the winscp.com commands sucha as "exit /b" ?
Re: exit command at the end of winscp.com command closes all windows and the batch script cannot continu
Your batch file works for me correctly (you should not really post your credentials).
If it does not work for you, my guess is that you have a space after ...Download" ^, what got lost when posting the code on the forum.
If this does not help, please post the batch file zipped as an attachment, so that it stays intact.
The file works because this the one I have created as a workaround. The problem happens when I put that code within another script that deals with the files after being downloaded. For example in the script I have logic to unzip the files but that logic is not executed because the exit, as I mentioned, terminate the script and only the winscp.com commands are executed. By the way can you please scramble the credentials?
Your batch file works for me. I do not know how to help you.
Note that you have a tab instead of space before exit command. But even that way, it works for me.
Thanks Martin. I removed the TAB before the exit command and now it is working both from the command line and from Windows task scheduler.
