winSCP window moves
vamm
winSCP window moves
after any winSCP window minimizing when i open it again, the window has been moved into right corner of the display, all the view has been minimized to some minimum view with one row visible.
why does it not just stay as is? why minimizing the app has that weird influence?
Re: winSCP window moves
WinSCP does not do that. At least not for most users.
Can you tell us more about your system? What version of Windows are you using? Do you have any desktop-enhancing applications installed? How many displays do you have? Etc.
vamm
it is a very new Asus laptop, win 10. One monitor so far, and of course still there are not any complex apps installed, just basic. After several switches between windows (even without minimizing) i see what you can see too in attached
vamm
hi i sent am email to you from email starts from ag...
