Using TLS with sessionurl
AndersRisager
Danmark
I am trying to use the the PowerShell script supplied here which makes it possible to have uploads in parallel. This will boost performance in my scenario by a mile, because I upload about 3000 files.
Automating transfers or synchronization in parallel connections over SFTP/FTP protocol
My problem is that the host uses TLS and not SFTP, and it seems the session URL does not support the TLS thumbprint. The fingerprint is only for SFTP.
If I connect without the hosts certificate thumbprint, it will give me the error "Peer certificate rejected". I can connect without using TLS, but I prefer TLS.
Is it possible to execute the batches in some other way than using session URL or can the TLS thumbprint be applied in some other way?
Re: Using TLS with sessionurl
TLS/SSL certificate fingerprint can be provided the same way as SSH host key fingerprints.
The next version of WinSCP will even allow you to generate the URL with the fingerprint.
Issue 1646 – Generated session URL for opened FTP/WebDAV session over TLS/SSL with invalid certificate includes its fingerprint
AndersRisager
Danmark
Thx for the fast reply. I will be looking forward to the dev version ; )
I tried to add the fingerprint like this, but I guess the syntax is wrong then:
$sessionUrl = "ftpes://[Username]:[Password];fingerprint=sha1-[Thumbprint]@[FtpDomain]"
It gives me this error:
SSH host key fingerprint "sha1-[Thumbprint]" does not match pattern /((ssh-rsa|ssh-dss|ssh-ed25519|ecdsa-sha2-nistp(256|384|521))( |-))?(\d+ )?(([0-9a-f]{2}(:|-)){
15}[0-9a-f]{2}|[0-9a-zA-Z+/]{43}=)(;((ssh-rsa|ssh-dss|ssh-ed25519|ecdsa-sha2-nistp(256|384|521))( |-))?(\d+ )?(([0-9a-f]{2}(:|-)){15}[0-9a-f]{2}|[0-9a-zA-Z+/]{43}=))*/
I can see that sha1 is not part of this list ssh-rsa|ssh-dss|ssh-ed25519|ecdsa-sha2-nistp, but have tried those as well.
I could not find clues about this problem in the sessionUrl documentation.
Just remove the sha1- part. For example:
ftpes://username:password;fingerprint=90:1a:bd:7a:bb:0d:0f:44:3d:bd:f0:2e:c6:4d:bb:b6:f9:58:f5:2d@example.com/
