Asking for help!! Open connection via WinSCP in Powerbuilder10.
tiver109
Taiwan
HI everyone, I get some problem when I'm trying to open a ftp connection via WinSCP in Powerbuilder10. Hope that someone can help me. Orz
This is my Code :
integer li_err,li_err2
oleobject lo_SessionOptions, lo_Session, lo_remoteDirectoryInfo, lo_TransferOperationResult, lo_TransferOptions,lo_Protocol
TRY
    lo_SessionOptions = create oleobject
    li_err = lo_SessionOptions.connecttonewobject("WinSCP.SessionOptions")
    lo_sessionOptions.Protocol = 2
    lo_SessionOptions.HostName = "192.168.1.50"
    lo_SessionOptions.UserName = "ftp_user"
    lo_SessionOptions.Password = "123456"
    lo_SessionOptions.PortNumber = 21
    lo_SessionOptions.FtpMode = 0
    lo_Session = create oleobject
    li_err2 = lo_Session.connecttonewobject("WinSCP.Session")
    if lo_Session.Opened then
   lo_Session.Abort()
    end if
   lo_Session.Open(lo_SessionOptions)
CATCH (OLERuntimeError exRuntime)
    messagebox("error",string(exRuntime))
END TRY
There are two problem that I've got.
First is the propertise of SessionOptions Protocol. I know that document say that the value will be something like Protocol.Sftp or Protocol.ftp. but I can't make powerbuilder recognize type protocol, so I set it to integer value 2(
assuming it's start from 0). How can i set this propertise?
Second is I get the error when running open method. The error just says "Error calling external object function open at line xx in clicked event .....", and OLERuntimeError exRuntime is always null.
p.s I've already Registry the dll. the li_err when connecttonewobject is 0.
Can anyone help me? Thanks a lot!!
tiver109, 20180604
Re: Asking for help!! Open connection via WinSCP in Powerbuilder10.
I have no experience with PowerBuilder.
But do try setting lo_Session.SesisionLogPath = "C:\some\path\session.log"
And inspect the log file, or attach it here.
tiver109
Taiwan
Hi, Martin
Thanks for your reply !
I've set the SesisionLogPath, but it's didn't generat anything.
And I try to create a .log file before i excute the program. The .log file still be empty.
This is how I set :
lo_Session.SessionLogPath = "C:\winscp\session.log"
Sorry, we cannot help you with PowerBuilder.
tiver109
Taiwan
Re: WinSCP and Powerbuilder
tibor84 wrote:
hi tiver109,
did you succed? i am solving similar problem like you.
Sadly, I did't success, so i tried another way, using Microsoft Winnet.dll without SSH.
tiver109
Taiwan
It's okay, thanks for you reply.
tibor84
Slovakia
tiver109 wrote:
tibor84 wrote:
hi tiver109,
I succeed with this in powerbuilder:
0. Install & register WinSCP dll, so you can see it in powebuilder components in active x part
1. i create new standard with Type oleobject
(File -> New -> PBObject -> Standard class -> oleobject
2. Save as n_myole, and add this source to externalexception
messagebox("External Error", string(resultcode) + ": " + description)
3. Sample source:
n_myole s_ftp // for WinSCP.Session
n_myole s_opt // for WinSCP.sessionoptions
n_myole s_trans // for WinSCP.TransferOptions, i just used default values (Binary transfer and overwrite options)
int return_code
s_ftp = CREATE n_myole
return_code = s_ftp.connecttonewobject("WinSCP.Session")
if return_code <> 0 then
   messagebox("Error", "S_FTP Component installation error")
   return - 1
end if
s_opt = CREATE n_myole
return_code = s_opt.connecttonewobject("WinSCP.sessionoptions")
   messagebox("Error", "Seasion Options  Component installation error")
   return - 1
end if
s_trans = CREATE n_myole
return_code = s_trans.connecttonewobject("WinSCP.TransferOptions")
   messagebox("Error", "Transfer Options Component installation error")
   return - 1
end if
s_opt.protocol = 0 // SFTP - i couldn't use WinSCP constans
s_opt.hostname = i_server_ip // server IP
s_opt.UserName = i_user_name // user id
s_opt.Password = i_user_pass // user pass
s_opt.GiveUpSecurityAndAcceptAnySshHostKey = true  // this is not save, instead server key should be used
try
   any result
   result = s_ftp.open(s_opt)
   return  integer(result)
catch (runtimeerror  e)
  messagebox("Error",e.getMessage())
return -1
end try
Ll_rtn = integer (s_ftp.putfiles(source_file, target_file, false,s_trans ) )
IF Ll_rtn < 0 THEN
   as_msg   =   "File Upload Error(FTP)!"
END IF
s_ftp.close()
I don't know how to use winscp constans for setup details. If somebody could just paste value for each options like:
binnary = 0
overwrite = 0
Edit1:
i created my custom object to catch winscp errors
