Authenticate ssh tunnel with private key with no passphrase
moeck
to avoid the input of the passphrase when using a private key file I generated a private key without a passphrase. When I now set the raw settings with
_sessionOptions.AddRawSettings("TunnelPublicKeyFile", _privateKeyPathNoPassPhrase);
and try to connect I get the error
"unable to use key file 'nopassphrase.ppk' (unable to open file).
If I start pageant and register the no passphrase key before trying to connect, connection succeeds.
How can I connect without using pageant?
Regards
moeck
moeck
Re: Authenticate ssh tunnel with private key with no passphrase
Did you try using a full path to the key?
No, the key file is located in a "keys"-subfolder. So the path is relative.
But it would be a surprise if this would be the problem because if I use pageant as I mentioned the connection succeeds without modifying the path.
But the error message says nopassphrase.ppk, not keys/nopassphrase.ppk - And can you try a full path anyway? Just for a test.
That's irrelevant.
moeck
hi martin,
i tried the full path today and it worked by surprise.
I must admit that i quoted the error message not properly. It correctly said "unable to use key file 'Keys/nopassphrase.ppk' (unable to open file).
So i edited the code to put together the full path by using application path and the initial relative path.
Thx for the help :)
