open sftp command reporting 'Too Many Parameters'
DJBurner
Ireland
Hi Gurus,
Having difficulty with a script I have wrote and when I type the open sftp line into the WinSCP command prompt, it says "too many parameters". But if I try the same connection and take out the -hostkey section it connects, but prompts me to accept connection so cannot be automated, can someone let me know what I am doing wrong, my open line is:
open sftp://user:password@server/ -hostkey="ssh-rsa ab:cd:ef:ab:cd:ef............"
Re: open sftp command reporting 'Too Many Parameters'
You may be using some very old version of WinSCP.
If you have the latest version, please attach a full session log file showing the problem.
DJBurner
Hi Martin,
Thank you, I upgraded my version from 4.07 to 5.13 and then it gave me the option to generate the script, I tried that and it worked fine, thanks a million.
