Error put command in specific folder
andrerca
I'm trying to copy a folder from one Windows Server to another, using this command:
open sftp://myuser:mypw@172.16.49.2/
put -nopermissions -nopreservetime "C:\scp\Testecopia" "D:\Testecopia"
In my understanding, "C:\scp\Testecopia" is the source in source server and "D:\Testecopia" the destination in destination server.
Error:
Error creating folder /C:/Users/myuser/D:Testecopia/'
Bad message <badly formatted packet or protocol incompatibility>;
Error code: 5
Error message from server: Bad message
I appreciate any help i can get.
Re: Error put command in specific folder
SFTP protocol always uses forward slashes, even when you are connected to a Windows machine.
Login with WinSCP GUI and check a remote file panel for the correct path syntax that your SFTP server uses.
You can even have the GUI generate a script template for you:
https://winscp.net/eng/docs/ui_generateurl#script
