Drag & Drop between two servers fails
sorry, my english is not very whell, but i hope you understand me :-)
i'am using winscp to copy files between two servers.
server A is connected via ftp, server B via ssh.
drag & drop setting is "use temp-dir". winscp runs in two windows (explorer-mode).
now, i drag & drop files (and directories) from server A to server B. winscp starts to download all files into the temp-folder. after download is finished, winscp begins to copy the files to server B. the problem is, winscp delete the temp-folder automatically befor copyed all files to server B. all settings i tested have no effect. how can i disable temp-folder-auto-delete?
great thanks for help!
