Public key authetication is passed to PUTTY (or not working) in latest version
ttomika
Hi all,
In version 5.13.3 when opening Putty from WinSCP session key seems to be not passed.
This works with previous versions.
May I missed a new setting or something?
Thanks for your help in advance.
Best Regards,
Tom
Re: Public key authetication is passed to PUTTY (or not working) in latest version
What versions were you using previously? Did it work in 5.13.2?
ttomika
I can't remember so downloaded and tried 5.13.2.
That version works fine.
Best Regards,
Tom
Please host down Ctrl+Shift when clicking on "Open in PuTTY" command in both versions.
It makes WinSCP copy PuTTY command-line to clipboard. Post commands from both versions.
ttomika
Old: "C:\Program Files (x86)\PuTTY\putty.exe" - load "WinSCP temporary session"
New: "C:\Program Files (x86)\PuTTY\putty.exe" 192.168.1.10 - l user - P 1234
Best Regards,
Tom
There's no difference between 5.13.2 and 5.13.3 that can cause this.
But this difference can be caused by you having 5.13.3 installed from Microsoft Store, while 5.13.2 installed by WinSCP installer. Isn't this the case?
ttomika
Absolutely this is the case. I've choosen this way of donation as it is suggested on the website. I hoped that this way new versions will be automatically installed.
Is there a way to make this function work in MS Store version or I have to return to the standalone version?
Best Regards,
Tom
The next version will pass private key to PuTTY even when installed from Store:
https://winscp.net/tracker/1654
