Timestamps on Files in SFTP Session Are All 12/30/1899
Log file below.
. 2018-06-24 09:05:54.729 -------------------------------------------------------------------------- . 2018-06-24 09:05:54.729 WinSCP Version 5.11.3 (Build 7995) (OS 10.0.17134 - Windows 10 Enterprise) . 2018-06-24 09:05:54.730 Configuration: C:\Portable Applications\WinSCPPortable\Data\settings\winscp.ini . 2018-06-24 09:05:54.730 Log level: Normal . 2018-06-24 09:05:54.730 Local account: DELL-XPS-9100\Randy . 2018-06-24 09:05:54.730 Working directory: C:\Portable Applications\WinSCPPortable\App\WinSCP . 2018-06-24 09:05:54.730 Process ID: 2072 . 2018-06-24 09:05:54.732 Command-line: "C:\Portable Applications\WinSCPPortable\App\WinSCP\WinSCP.exe" /ini="C:\Portable Applications\WinSCPPortable\Data\settings\winscp.ini" /log="C:\Portable Applications\WinSCPPortable\Data\settings\winscp.log" . 2018-06-24 09:05:54.732 Time zone: Current: GMT-7, Standard: GMT-8 (Pacific Standard Time), DST: GMT-7 (Pacific Daylight Time), DST Start: 3/11/2018, DST End: 11/4/2018 . 2018-06-24 09:05:54.732 Login time: Sunday, June 24, 2018 9:05:54 AM . 2018-06-24 09:05:54.732 -------------------------------------------------------------------------- . 2018-06-24 09:05:54.732 Session name: SRT - SFTP (Site) . 2018-06-24 09:05:54.732 Host name: shoestring.org (Port: 2222) . 2018-06-24 09:05:54.732 User name: shoestring (Password: Yes, Key file: No, Passphrase: No) . 2018-06-24 09:05:54.732 Tunnel: No . 2018-06-24 09:05:54.732 Transfer Protocol: SFTP (SCP) . 2018-06-24 09:05:54.732 Ping type: Off, Ping interval: 30 sec; Timeout: 60 sec . 2018-06-24 09:05:54.732 Disable Nagle: No . 2018-06-24 09:05:54.732 Proxy: None . 2018-06-24 09:05:54.732 Send buffer: 262144 . 2018-06-24 09:05:54.732 SSH protocol version: 2; Compression: No . 2018-06-24 09:05:54.732 Bypass authentication: No . 2018-06-24 09:05:54.732 Try agent: Yes; Agent forwarding: No; TIS/CryptoCard: No; KI: Yes; GSSAPI: Yes . 2018-06-24 09:05:54.732 GSSAPI: Forwarding: No . 2018-06-24 09:05:54.732 Ciphers: aes,chacha20,blowfish,3des,WARN,arcfour,des; Ssh2DES: No . 2018-06-24 09:05:54.732 KEX: ecdh,dh-gex-sha1,dh-group14-sha1,rsa,dh-group1-sha1,WARN . 2018-06-24 09:05:54.732 SSH Bugs: Auto,Auto,Auto,Auto,Auto,Auto,Auto,Auto,Auto,Auto,Auto,Auto,Auto . 2018-06-24 09:05:54.732 Simple channel: Yes . 2018-06-24 09:05:54.732 Return code variable: Autodetect; Lookup user groups: Auto . 2018-06-24 09:05:54.732 Shell: default . 2018-06-24 09:05:54.732 EOL: LF, UTF: Auto . 2018-06-24 09:05:54.732 Clear aliases: Yes, Unset nat.vars: Yes, Resolve symlinks: Yes; Follow directory symlinks: No . 2018-06-24 09:05:54.732 LS: ls -la, Ign LS warn: Yes, Scp1 Comp: No . 2018-06-24 09:05:54.732 SFTP Bugs: Auto,Auto . 2018-06-24 09:05:54.732 SFTP Server: default . 2018-06-24 09:05:54.733 Local directory: D:\Users\Randy\Documents\Web Sites\Shoestring\html, Remote directory: /web04/shoestring/html, Update: Yes, Cache: Yes . 2018-06-24 09:05:54.733 Cache directory changes: Yes, Permanent: Yes . 2018-06-24 09:05:54.733 Recycle bin: Delete to: No, Overwritten to: No, Bin path: . 2018-06-24 09:05:54.733 DST mode: Win . 2018-06-24 09:05:54.733 -------------------------------------------------------------------------- . 2018-06-24 09:05:54.777 Looking up host "shoestring.org" for SSH connection . 2018-06-24 09:05:54.808 Connecting to 216.218.198.56 port 2222 . 2018-06-24 09:05:54.833 We claim version: SSH-2.0-WinSCP_release_5.11.3 . 2018-06-24 09:06:28.992 Server version: SSH-1.99-2.0.13 (non-commercial) . 2018-06-24 09:06:28.992 We believe remote version has SSH-2 HMAC bug . 2018-06-24 09:06:28.992 Using SSH protocol version 2 . 2018-06-24 09:06:29.005 Have a known host key of type dss . 2018-06-24 09:06:29.013 Using Diffie-Hellman with standard group "group1" . 2018-06-24 09:06:29.013 Doing Diffie-Hellman key exchange with hash SHA-1 . 2018-06-24 09:06:29.235 Host key fingerprint is: . 2018-06-24 09:06:29.235 ssh-dss 1024 61:02:c1:7e:6a:82:99:0d:be:69:f7:95:e8:43:64:a8 . 2018-06-24 09:06:29.235 Verifying host key dss 0xe051d4b3938bd0b3 5a8b5b700f3f6971 1e66397c382f8b87 03f0ef73358c5386 c6e2ede86921ee25 4cf0bf9c25afbc4d 451432250a0e40e6 90841da76f10e28f 66b4bfed1fc6492f e84f9242d19c4deb 96cf03ad3d991522 7c4e2f11903194ca 376c3522a6630fae 0b91cc031525cfb5 b36c07841eea9aa0 d32ec9bd963ca927 ,0xd70d0fe9d7eab8c4 d3f30c67af893435 99521ad7,0xbab7626799782bed 3a95badbc75523f7 4f8053e0db8c8bf1 7b925478c7a6f48b 91d6b4f98ca31305 1baddd3cb1792ca3 ed1a1c5194ba1dfd 45313da93e10e65d 0ca8975e22ea8893 d8cb5a0e3e15c8a4 372fa142d73ff0e7 74700278ad4eba59 29ee8d93483e608d 7b977e669e0f8967 db2b8c3626b72ae2 0cdc803054a77f54 ,0xb794980f57cf9b51 dc257557f4a93d9a 8cb09856dabebc3d 599c623c851d2463 89e485d7428a05ed 5ea7f1f9f8345003 478878b1ab702ccf 4ce1dd2ea0da1368 b77f37421890710a 0a3dff9b70c9b5db 5988b9c0cee67eda 520af250773c46d0 6d923a4eab3aee05 4a3a4fb16101bc2a 3a7821b465fe710c 958db9a0fd58cd8c with fingerprint ssh-dss 1024 61:02:c1:7e:6a:82:99:0d:be:69:f7:95:e8:43:64:a8 . 2018-06-24 09:06:29.262 Host key matches cached key . 2018-06-24 09:06:29.262 Initialised Blowfish-128 CBC client->server encryption . 2018-06-24 09:06:29.262 Initialised HMAC-MD5 client->server MAC algorithm . 2018-06-24 09:06:29.262 Initialised Blowfish-128 CBC server->client encryption . 2018-06-24 09:06:29.262 Initialised HMAC-MD5 server->client MAC algorithm ! 2018-06-24 09:06:29.288 Using username "shoestring". . 2018-06-24 09:06:29.331 Server offered these authentication methods: publickey,password . 2018-06-24 09:06:29.334 Prompt (password, "SSH password", <no instructions>, "&Password: ") . 2018-06-24 09:06:29.334 Using stored password. . 2018-06-24 09:06:29.374 Sent password . 2018-06-24 09:06:29.404 Access granted . 2018-06-24 09:06:29.404 Opening session as main channel . 2018-06-24 09:06:29.431 Opened main channel . 2018-06-24 09:06:29.464 Started a shell/command . 2018-06-24 09:06:29.486 -------------------------------------------------------------------------- . 2018-06-24 09:06:29.491 Using SFTP protocol. . 2018-06-24 09:06:29.493 Doing startup conversation with host. > 2018-06-24 09:06:29.508 Type: SSH_FXP_INIT, Size: 5, Number: -1 < 2018-06-24 09:06:29.765 Type: SSH_FXP_VERSION, Size: 5, Number: -1 . 2018-06-24 09:06:29.766 SFTP version 0 negotiated. . 2018-06-24 09:06:29.766 We believe the server has signed timestamps bug . 2018-06-24 09:06:29.766 We will use UTF-8 strings until server sends an invalid UTF-8 string as with SFTP version 3 and older UTF-8 strings are not mandatory . 2018-06-24 09:06:29.766 Changing directory to "/web04/shoestring/html". . 2018-06-24 09:06:29.767 Getting real path for '/web04/shoestring/html' > 2018-06-24 09:06:29.767 Type: SSH_FXP_REALPATH, Size: 31, Number: 16 < 2018-06-24 09:06:29.798 Type: SSH_FXP_NAME, Size: 65, Number: 16 . 2018-06-24 09:06:29.798 Real path is '/web04/shoestring/html' . 2018-06-24 09:06:29.799 Trying to open directory "/web04/shoestring/html". > 2018-06-24 09:06:29.799 Type: SSH_FXP_LSTAT, Size: 31, Number: 263 < 2018-06-24 09:06:29.806 Type: SSH_FXP_ATTRS, Size: 37, Number: 263 . 2018-06-24 09:06:29.807 Getting current directory name. . 2018-06-24 09:06:29.859 Listing directory "/web04/shoestring/html". > 2018-06-24 09:06:29.859 Type: SSH_FXP_OPENDIR, Size: 31, Number: 523 < 2018-06-24 09:06:29.866 Type: SSH_FXP_HANDLE, Size: 17, Number: 523 > 2018-06-24 09:06:29.866 Type: SSH_FXP_READDIR, Size: 17, Number: 780 < 2018-06-24 09:06:30.242 Type: SSH_FXP_NAME, Size: 9979, Number: 780 > 2018-06-24 09:06:30.242 Type: SSH_FXP_READDIR, Size: 17, Number: 1036 < 2018-06-24 09:06:30.345 Type: SSH_FXP_STATUS, Size: 9, Number: 1036 < 2018-06-24 09:06:30.345 Status code: 1 > 2018-06-24 09:06:30.345 Type: SSH_FXP_CLOSE, Size: 17, Number: 1284 . 2018-06-24 09:06:30.347 ..;d;0;1899-12-30T08:00:00.000Z;3;"shoestring" [5743];"shoestring" [5743];rwxr-x---;0 . 2018-06-24 09:06:30.347 Stats;d;0;1899-12-30T08:00:00.000Z;3;"shoestring" [5743];"shoestring" [5743];rwxrwxr-x;0 . 2018-06-24 09:06:30.347 search.html;-;1952;1899-12-30T08:00:00.000Z;3;"shoestring" [5743];"shoestring" [5743];rw-r-----;0 . 2018-06-24 09:06:30.347 robots.txt;-;14;1899-12-30T08:00:00.000Z;3;"shoestring" [5743];"shoestring" [5743];rw-r-----;0 . 2018-06-24 09:06:30.347 mmi_contests.html;-;10488;1899-12-30T08:00:00.000Z;3;"shoestring" [5743];"shoestring" [5743];rw-r-----;0 . 2018-06-24 09:06:30.347 mmi_alpha_j-l.html;-;13488;1899-12-30T08:00:00.000Z;3;"shoestring" [5743];"shoestring" [5743];rw-r-----;0 . 2018-06-24 09:06:30.347 srtlocal.html;-;7447;1899-12-30T08:00:00.000Z;3;"shoestring" [5743];"shoestring" [5743];rw-r-----;0 . 2018-06-24 09:06:30.347 srtnatl.html;-;8099;1899-12-30T08:00:00.000Z;3;"shoestring" [5743];"shoestring" [5743];rw-r-----;0 . 2018-06-24 09:06:30.347 srthome.html;-;6730;1899-12-30T08:00:00.000Z;3;"shoestring" [5743];"shoestring" [5743];rw-r-----;0 . 2018-06-24 09:06:30.348 srt_who.html;-;8041;1899-12-30T08:00:00.000Z;3;"shoestring" [5743];"shoestring" [5743];rw-r-----;0 . 2018-06-24 09:06:30.348 srt_submit.html;-;5404;1899-12-30T08:00:00.000Z;3;"shoestring" [5743];"shoestring" [5743];rw-r-----;0 . 2018-06-24 09:06:30.348 srt_news.html;-;48600;1899-12-30T08:00:00.000Z;3;"shoestring" [5743];"shoestring" [5743];rw-r-----;0 . 2018-06-24 09:06:30.348 srt_links.html;-;7483;1899-12-30T08:00:00.000Z;3;"shoestring" [5743];"shoestring" [5743];rw-r-----;0 . 2018-06-24 09:06:30.348 srt_feed.html;-;2971;1899-12-30T08:00:00.000Z;3;"shoestring" [5743];"shoestring" [5743];rw-r-----;0 . 2018-06-24 09:06:30.348 srt_comments.html;-;11125;1899-12-30T08:00:00.000Z;3;"shoestring" [5743];"shoestring" [5743];rw-r-----;0 . 2018-06-24 09:06:30.348 mmi_alpha.html;-;4496;1899-12-30T08:00:00.000Z;3;"shoestring" [5743];"shoestring" [5743];rw-r-----;0 . 2018-06-24 09:06:30.348 query_response.html;-;1869;1899-12-30T08:00:00.000Z;3;"shoestring" [5743];"shoestring" [5743];rw-r-----;0 . 2018-06-24 09:06:30.348 randy;d;0;1899-12-30T08:00:00.000Z;3;"shoestring" [5743];"shoestring" [5743];rwxr-x---;0 . 2018-06-24 09:06:30.348 query.html;-;6425;1899-12-30T08:00:00.000Z;3;"shoestring" [5743];"shoestring" [5743];rw-r-----;0 . 2018-06-24 09:06:30.348 mmihome.html;-;7586;1899-12-30T08:00:00.000Z;3;"shoestring" [5743];"shoestring" [5743];rw-r-----;0 . 2018-06-24 09:06:30.348 mmi_who.html;-;7237;1899-12-30T08:00:00.000Z;3;"shoestring" [5743];"shoestring" [5743];rw-r-----;0 . 2018-06-24 09:06:30.348 todo;d;0;1899-12-30T08:00:00.000Z;3;"shoestring" [5743];"shoestring" [5743];rwxr-x---;0 . 2018-06-24 09:06:30.348 Templates;d;0;1899-12-30T08:00:00.000Z;3;"shoestring" [5743];"shoestring" [5743];rwxr-x---;0 . 2018-06-24 09:06:30.348 Test;d;0;1899-12-30T08:00:00.000Z;3;"shoestring" [5743];"shoestring" [5743];rwxr-x---;0 . 2018-06-24 09:06:30.348 CSS;d;0;1899-12-30T08:00:00.000Z;3;"shoestring" [5743];"shoestring" [5743];rwxr-x---;0 . 2018-06-24 09:06:30.348 mmi_surf.html;-;23427;1899-12-30T08:00:00.000Z;3;"shoestring" [5743];"shoestring" [5743];rw-r-----;0 . 2018-06-24 09:06:30.348 mmi_news.html;-;21464;1899-12-30T08:00:00.000Z;3;"shoestring" [5743];"shoestring" [5743];rw-r-----;0 . 2018-06-24 09:06:30.348 mmi_intv.html;-;17221;1899-12-30T08:00:00.000Z;3;"shoestring" [5743];"shoestring" [5743];rw-r-----;0 . 2018-06-24 09:06:30.348 mmi_ifg.html;-;5786;1899-12-30T08:00:00.000Z;3;"shoestring" [5743];"shoestring" [5743];rw-r-----;0 . 2018-06-24 09:06:30.348 .htaccess;-;234;1899-12-30T08:00:00.000Z;3;"shoestring" [5743];"shoestring" [5743];rw-r-----;2 . 2018-06-24 09:06:30.348 mmi_guests.html;-;19543;1899-12-30T08:00:00.000Z;3;"shoestring" [5743];"shoestring" [5743];rw-r-----;0 . 2018-06-24 09:06:30.348 mmi_feed.html;-;3278;1899-12-30T08:00:00.000Z;3;"shoestring" [5743];"shoestring" [5743];rw-r-----;0 . 2018-06-24 09:06:30.348 Library;d;0;1899-12-30T08:00:00.000Z;3;"shoestring" [5743];"shoestring" [5743];rwxr-x---;0 . 2018-06-24 09:06:30.348 googlee6729de1e0f1442f.html;-;145;1899-12-30T08:00:00.000Z;3;"shoestring" [5743];"shoestring" [5743];rw-r-----;0 . 2018-06-24 09:06:30.348 mmi_comments.html;-;10842;1899-12-30T08:00:00.000Z;3;"shoestring" [5743];"shoestring" [5743];rw-r-----;0 . 2018-06-24 09:06:30.348 mmi_books.html;-;20097;1899-12-30T08:00:00.000Z;3;"shoestring" [5743];"shoestring" [5743];rw-r-----;0 . 2018-06-24 09:06:30.348 listen.html;-;6316;1899-12-30T08:00:00.000Z;3;"shoestring" [5743];"shoestring" [5743];rw-r-----;0 . 2018-06-24 09:06:30.348 imdb;d;0;1899-12-30T08:00:00.000Z;3;"shoestring" [5743];"shoestring" [5743];rwxr-x---;0 . 2018-06-24 09:06:30.348 favicon.ico;-;18670;1899-12-30T08:00:00.000Z;3;"shoestring" [5743];"shoestring" [5743];rw-r-----;0 . 2018-06-24 09:06:30.348 mmi_alpha_a-c.html;-;26839;1899-12-30T08:00:00.000Z;3;"shoestring" [5743];"shoestring" [5743];rw-r-----;0 . 2018-06-24 09:06:30.348 index.html;-;4400;1899-12-30T08:00:00.000Z;3;"shoestring" [5743];"shoestring" [5743];rw-r-----;0 . 2018-06-24 09:06:30.348 credits.html;-;3945;1899-12-30T08:00:00.000Z;3;"shoestring" [5743];"shoestring" [5743];rw-r-----;0 . 2018-06-24 09:06:30.348 corp_who.html;-;3184;1899-12-30T08:00:00.000Z;3;"shoestring" [5743];"shoestring" [5743];rw-r-----;0 . 2018-06-24 09:06:30.348 mmi_trivia;d;0;1899-12-30T08:00:00.000Z;3;"shoestring" [5743];"shoestring" [5743];rwxr-x---;0 . 2018-06-24 09:06:30.348 review_comments;d;0;1899-12-30T08:00:00.000Z;3;"shoestring" [5743];"shoestring" [5743];rwxr-x---;0 . 2018-06-24 09:06:30.348 sounds;d;0;1899-12-30T08:00:00.000Z;3;"shoestring" [5743];"shoestring" [5743];rwxr-x---;0 . 2018-06-24 09:06:30.348 web_art;d;0;1899-12-30T08:00:00.000Z;3;"shoestring" [5743];"shoestring" [5743];rwxr-x---;0 . 2018-06-24 09:06:30.348 staff;d;0;1899-12-30T08:00:00.000Z;3;"shoestring" [5743];"shoestring" [5743];rwxr-x---;0 . 2018-06-24 09:06:30.348 mmi_revs;d;0;1899-12-30T08:00:00.000Z;3;"shoestring" [5743];"shoestring" [5743];rwxr-x---;0 . 2018-06-24 09:06:30.348 mmi_alpha_p-r.html;-;13386;1899-12-30T08:00:00.000Z;3;"shoestring" [5743];"shoestring" [5743];rw-r-----;0 . 2018-06-24 09:06:30.348 mmi_alpha_d-f.html;-;17978;1899-12-30T08:00:00.000Z;3;"shoestring" [5743];"shoestring" [5743];rw-r-----;0 . 2018-06-24 09:06:30.348 mmi_alpha_g-i.html;-;17197;1899-12-30T08:00:00.000Z;3;"shoestring" [5743];"shoestring" [5743];rw-r-----;0 . 2018-06-24 09:06:30.348 mmi_alpha_s-u.html;-;22294;1899-12-30T08:00:00.000Z;3;"shoestring" [5743];"shoestring" [5743];rw-r-----;0 . 2018-06-24 09:06:30.348 mmi_alpha_v-z.html;-;13342;1899-12-30T08:00:00.000Z;3;"shoestring" [5743];"shoestring" [5743];rw-r-----;0 . 2018-06-24 09:06:30.348 mmi_alpha_m-o.html;-;17936;1899-12-30T08:00:00.000Z;3;"shoestring" [5743];"shoestring" [5743];rw-r-----;0 . 2018-06-24 09:06:30.348 mmi_interviews;d;0;1899-12-30T08:00:00.000Z;3;"shoestring" [5743];"shoestring" [5743];rwxr-x---;0 . 2018-06-24 09:06:30.348 JavaScript;d;0;1899-12-30T08:00:00.000Z;3;"shoestring" [5743];"shoestring" [5743];rwxr-x---;0 . 2018-06-24 09:06:30.349 mmi_alpha__special.html;-;30311;1899-12-30T08:00:00.000Z;3;"shoestring" [5743];"shoestring" [5743];rw-r-----;0 . 2018-06-24 09:06:30.349 page_not_found.html;-;1763;1899-12-30T08:00:00.000Z;3;"shoestring" [5743];"shoestring" [5743];rw-r-----;0 . 2018-06-24 09:06:30.349 IpsThumb.db;-;850;1899-12-30T08:00:00.000Z;3;"shoestring" [5743];"shoestring" [5743];rw-r-----;0 . 2018-06-24 09:06:30.349 mmi_intv.bak;-;10356;1899-12-30T08:00:00.000Z;3;"shoestring" [5743];"shoestring" [5743];rw-r-----;0 . 2018-06-24 09:06:30.349 mmi_alpha_a-z.html;-;179871;1899-12-30T08:00:00.000Z;3;"shoestring" [5743];"shoestring" [5743];rw-r-----;0 . 2018-06-24 09:06:30.349 test_mmi_alpha.php3;-;8461;1899-12-30T08:00:00.000Z;3;"shoestring" [5743];"shoestring" [5743];rw-r-----;0 . 2018-06-24 09:06:30.349 mmi_alpha_a-z_new.html;-;170372;1899-12-30T08:00:00.000Z;3;"shoestring" [5743];"shoestring" [5743];rw-r-----;0 . 2018-06-24 09:06:30.349 mmi_alpha_special.html;-;21730;1899-12-30T08:00:00.000Z;3;"shoestring" [5743];"shoestring" [5743];rw-r-----;0 . 2018-06-24 09:06:30.349 mmi_alpha_a-z.php3;-;6430;1899-12-30T08:00:00.000Z;3;"shoestring" [5743];"shoestring" [5743];rw-r-----;0 . 2018-06-24 09:06:30.349 mmi_alpha_reviewer.php3;-;5591;1899-12-30T08:00:00.000Z;3;"shoestring" [5743];"shoestring" [5743];rw-r-----;0 . 2018-06-24 09:06:30.349 mmi_alpha_reviewer2.php3;-;4392;1899-12-30T08:00:00.000Z;3;"shoestring" [5743];"shoestring" [5743];rw-r-----;0 . 2018-06-24 09:06:30.349 mmi_alpha_reviewer.html;-;176432;1899-12-30T08:00:00.000Z;3;"shoestring" [5743];"shoestring" [5743];rw-r-----;0 . 2018-06-24 09:06:30.349 mmi_intvord_files;d;0;1899-12-30T08:00:00.000Z;3;"shoestring" [5743];"shoestring" [5743];rwxr-x---;0 . 2018-06-24 09:06:30.349 mmi_alpha_books.html;-;5378;1899-12-30T08:00:00.000Z;3;"shoestring" [5743];"shoestring" [5743];rw-r-----;0 . 2018-06-24 09:06:30.349 aprilreports.ZIP;-;188950;1899-12-30T08:00:00.000Z;3;"shoestring" [5743];"shoestring" [5743];rw-r-----;0 . 2018-06-24 09:06:30.349 bookmark.html;-;48878;1899-12-30T08:00:00.000Z;3;"shoestring" [5743];"shoestring" [5743];rw-r-----;0 . 2018-06-24 09:06:30.349 mmi_alpha_tributes.html;-;7963;1899-12-30T08:00:00.000Z;3;"shoestring" [5743];"shoestring" [5743];rw-r-----;0 . 2018-06-24 09:06:30.349 mmi_alpha_old.html;-;6674;1899-12-30T08:00:00.000Z;3;"shoestring" [5743];"shoestring" [5743];rw-r-----;0 . 2018-06-24 09:06:30.349 mmi_alpha_a-z_new_template.html;-;172146;1899-12-30T08:00:00.000Z;3;"shoestring" [5743];"shoestring" [5743];rw-r-----;0 . 2018-06-24 09:06:30.349 HTMLPage1.htm;-;41367;1899-12-30T08:00:00.000Z;3;"shoestring" [5743];"shoestring" [5743];rw-r-----;0 . 2018-06-24 09:06:30.349 mmi_alpha_a-z_generate.php3;-;7417;1899-12-30T08:00:00.000Z;3;"shoestring" [5743];"shoestring" [5743];rw-r-----;0 . 2018-06-24 09:06:30.349 mmi_alpha_reviewer_template.html;-;166775;1899-12-30T08:00:00.000Z;3;"shoestring" [5743];"shoestring" [5743];rw-r-----;0 . 2018-06-24 09:06:30.349 mmi_alpha_reviewer_generate.php3;-;6810;1899-12-30T08:00:00.000Z;3;"shoestring" [5743];"shoestring" [5743];rw-r-----;0 . 2018-06-24 09:06:30.349 mmi_intvWP.html;-;10602;1899-12-30T08:00:00.000Z;3;"shoestring" [5743];"shoestring" [5743];rw-r-----;0 . 2018-06-24 09:06:30.349 mmi_who-new.html;-;12900;1899-12-30T08:00:00.000Z;3;"shoestring" [5743];"shoestring" [5743];rw-r-----;0 . 2018-06-24 09:06:30.367 Startup conversation with host finished.
