session.FileExists not finding files
rsford31
I have to change an existing download process using a saved WinSCP session. I'm using a Powershell script to dynamically create a command file. The resulting command file is opening the saved WinSCP session.
The source directory to which I'm pulling files is /D:/bbsfiles/mucc.
I now need to check if the file at the source exists before download. Therefore I've changed the Powershell script to utilize the WinSCPnet.dll
As you can see I'm passing in the source directory, which would be "/D:/bbsfiles/mucc", etc. The protocol is FTP on port 21.
What I'm getting a failure on the first file stating that the file is not there. I manually FTP'd to the server to confirm that both the files are there.
I tried changing the source directory to just /bbsfiles/mucc, adding and removing quotes and nothing worked.
To test, I changed the script to connect to a different vendor. The protocol this time was FTPS on port 2010. The source for this connection was "/mucc/downloads". I was able to successfully download the files from this location.
I'm suspicious that it's the source location for the first vendor: /D:/bbsfiles/mucc
Any ideas?
I've tried WinSCPnet.dll for both WinSCP 5.7.5 and WinSCP 5.13
param($SourceDir, $DestDir,$CurrentDate, $hostIP, $userId, $password, $protocol)
try{
   $date = [datetime]::ParseExact($currentDate,"yyyyMMdd",$null)
   $date = $date.AddDays(-1)
   $date = $date.ToString("MMdd")
   Write-Host "Date " $date
   Add-Type -Path "E:\Program Files\WinSCP 5.13\WinSCPnet.dll"
        Protocol = [WinSCP.Protocol]::$protocol
        HostName = $hostIP
        UserName = $userId
        Password = $password
   try
      Write-Host $session.Opened
      $file1 = $SourceDir + "/M2MC" + $date + ".dat"
      $file2 = $SourceDir + "/M2MU" + $date + ".dat"
      $remotePath = $file1, $file2
      Write-Host $remotePath
        foreach($path in $remotePath){
         Write-Host "path " $path
         if ($session.FileExists($path)){
            Write-Host "File $path exists."
            $transferResult = $session.GetFiles($path, "E:\temp\Shelley\test\", $False, $Null)
            Write-Host $transferResult
            foreach ($transfer in $transferResult.Transfers)
            Write-Host "Download of $($transfer.FileName) succeeded"
         }else{
            Write-Host "File $path does not exist"
            exit 1
   finally{
      $session.Dispose()
}catch{
    exit 2
Re: session.FileExists not finding files
This still looks like the same problem we are discussing already in a separate thread:
https://winscp.net/forum/viewtopic.php?t=26414
Make sure you have a file name case right. If that does not help, please attach a full session log file showing the problem (using the latest version of WinSCP).
rsford31
Hi Martin,
Your assistance with my other post lead me to resolve this as well. It was in fact due to the name case not matching what was at the source.
Thanks so much!
