how to port over all the data / credentials from one installation to another
openSuseman
hello dear all,
love to hear from you
openSuseman
hello dear Requinix
many thanks - great:
followed this link.
https://winscp.net/eng/docs/config#transfer
Exporting/Backing up the Configuration
to export/back up your configuration, go to Tools > Export/Backup configuration on Login dialog.
well i did this - and was able to save a file called winSCP.ini
question : is this the whole magic!?
in other words: do i have with this saved file all i need.
and yes: if i port over this file to the new machine - into the apropiate folder - with a import dialog - is this all i need to do?
greetings
the link. https://winscp.net/eng/docs/config#transfer
Yes. Yes. Yes. As the documentation says.
