Infinite retry while trying to upload using Putfiles
Florence Daniel
I am using winscp to upload file to SFTP location. During call to PutFiles, the upload fails with below error and keeps retrying infinitely. Any idea what is missing here?
Thanks!
Complete Log:
. 2018-07-05 14:04:47.460 --------------------------------------------------------------------------
. 2018-07-05 14:04:47.460 WinSCP Version 5.7.3 (Build 5438) (OS 6.3.9600 - Windows Server 2012 R2 Standard)
. 2018-07-05 14:04:47.460 Configuration: nul
. 2018-07-05 14:04:47.460 Log level: Normal
. 2018-07-05 14:04:47.460 Local account: TPDBQA01\Administrator
. 2018-07-05 14:04:47.460 Working directory: D:\Dll
. 2018-07-05 14:04:47.460 Process ID: 51524
. 2018-07-05 14:04:47.460 Command-line: "D:\Dll\winscp.exe" /xmllog="C:\Users\Administrator\AppData\Local\Temp\2\wscp66E4.03027487.tmp" /xmlgroups /nointeractiveinput /dotnet=573 /ini=nul /log="F:\Work\QA\WinSCPLog2.txt" /console /consoleinstance=_26340_53710617_786
. 2018-07-05 14:04:47.460 Time zone: Current: GMT-4, Standard: GMT-5 (Eastern Standard Time), DST: GMT-4 (Eastern Daylight Time), DST Start: 3/11/2018, DST End: 11/4/2018
. 2018-07-05 14:04:47.460 Login time: Thursday, July 5, 2018 2:04:47 PM
. 2018-07-05 14:04:47.460 Script: Retrospectively logging previous script records:
> 2018-07-05 14:04:47.460 Script: option batch on
< 2018-07-05 14:04:47.460 Script: batch on
< 2018-07-05 14:04:47.460 Script: reconnecttime 120
> 2018-07-05 14:04:47.460 Script: option confirm off
< 2018-07-05 14:04:47.460 Script: confirm off
> 2018-07-05 14:04:47.460 Script: option reconnecttime 120
> 2018-07-05 14:04:47.460 Script: open sftp://Regeneron_QA:***@ftp.physiciansworld.com:22 -hostkey="ssh-rsa 2048 bc:9d:86:20:2d:68:1a:35:bb:9d:5c:41:f4:eb:69:4c;*" -timeout=15 -rawsettings SFTPMaxVersion="3"
. 2018-07-05 14:04:47.460 Session name: Regeneron_QA@ftp.physiciansworld.com (Ad-Hoc site)
. 2018-07-05 14:04:47.460 Host name: ftp.physiciansworld.com (Port: 22)
. 2018-07-05 14:04:47.460 User name: Regeneron_QA (Password: Yes, Key file: No)
. 2018-07-05 14:04:47.460 Tunnel: No
. 2018-07-05 14:04:47.460 Transfer Protocol: SFTP
. 2018-07-05 14:04:47.460 Ping type: -, Ping interval: 30 sec; Timeout: 15 sec
. 2018-07-05 14:04:47.460 Disable Nagle: No
. 2018-07-05 14:04:47.460 Proxy: none
. 2018-07-05 14:04:47.460 Send buffer: 262144
. 2018-07-05 14:04:47.460 SSH protocol version: 2; Compression: No
. 2018-07-05 14:04:47.460 Bypass authentication: No
. 2018-07-05 14:04:47.460 Try agent: Yes; Agent forwarding: No; TIS/CryptoCard: No; KI: Yes; GSSAPI: No
. 2018-07-05 14:04:47.460 Ciphers: aes,blowfish,3des,WARN,arcfour,des; Ssh2DES: No
. 2018-07-05 14:04:47.460 KEX: dh-gex-sha1,dh-group14-sha1,dh-group1-sha1,rsa,WARN
. 2018-07-05 14:04:47.460 SSH Bugs: A,A,A,A,A,A,A,A,A,A,A
. 2018-07-05 14:04:47.460 Simple channel: Yes
. 2018-07-05 14:04:47.460 Return code variable: Autodetect; Lookup user groups: A
. 2018-07-05 14:04:47.460 Shell: default
. 2018-07-05 14:04:47.460 EOL: 0, UTF: 2
. 2018-07-05 14:04:47.460 Clear aliases: Yes, Unset nat.vars: Yes, Resolve symlinks: Yes
. 2018-07-05 14:04:47.460 LS: ls -la, Ign LS warn: Yes, Scp1 Comp: No
. 2018-07-05 14:04:47.460 SFTP Bugs: A,A
. 2018-07-05 14:04:47.460 SFTP Server: default
. 2018-07-05 14:04:47.460 Local directory: default, Remote directory: home, Update: Yes, Cache: Yes
. 2018-07-05 14:04:47.460 Cache directory changes: Yes, Permanent: Yes
. 2018-07-05 14:04:47.460 DST mode: 1
. 2018-07-05 14:04:47.460 Looking up host "ftp.physiciansworld.com"
. 2018-07-05 14:04:47.460 Connecting to 75.101.155.12 port 22
. 2018-07-05 14:04:47.492 Server version: SSH-2.0-HOSTED~FTP~ SFTP
. 2018-07-05 14:04:47.492 Using SSH protocol version 2
. 2018-07-05 14:04:47.492 We claim version: SSH-2.0-WinSCP_release_5.7.3
. 2018-07-05 14:04:47.507 Doing Diffie-Hellman group exchange
. 2018-07-05 14:04:47.757 Doing Diffie-Hellman key exchange with hash SHA-256
. 2018-07-05 14:04:48.601 Verifying host key rsa2 0x10001,0xb86483076b91960d a4665c0c611bcac0 53a56b48d49a9c40 d59363be876d9d24 83d9b1a365f63734 92597859e07885bb 232128b28c0291a4 aea81e2185f08d88 9911458c64bbfdf5 27a0b30f1161766a c27a627b1366f397 fb047568224d020f 67c212551fabb39d 5990fccd99ae463a e06ec2d941d8fa14 181e8b8b451758e8 a890b8ce11fd9e52 74de412a326128b6 07539a7f19a53b9f f270ce4507ad56b3 76f34465a421890a 482be6269c765901 bcb363d5879ff96c 4382ac90592469d8 5450ac2cd89f03d2 e2252c9656d17c06 da6a635edfac4d47 d074bf788d6a3efe c76f19d8dd2f4707 5d5c4e5293bb2b4e e6a08c6c3ea36f08 dcd9601ba09bfd2f with fingerprint ssh-rsa 2048 bc:9d:86:20:2d:68:1a:35:bb:9d:5c:41:f4:eb:69:4c
. 2018-07-05 14:04:48.601 Host key matches configured key
. 2018-07-05 14:04:48.601 Host key fingerprint is:
. 2018-07-05 14:04:48.601 ssh-rsa 2048 bc:9d:86:20:2d:68:1a:35:bb:9d:5c:41:f4:eb:69:4c
. 2018-07-05 14:04:48.601 Initialised AES-256 SDCTR client->server encryption
. 2018-07-05 14:04:48.601 Initialised HMAC-SHA-256 client->server MAC algorithm
. 2018-07-05 14:04:48.601 Initialised AES-256 SDCTR server->client encryption
. 2018-07-05 14:04:48.601 Initialised HMAC-SHA-256 server->client MAC algorithm
! 2018-07-05 14:04:48.632 Using username "Regeneron_QA".
. 2018-07-05 14:04:48.632 Attempting keyboard-interactive authentication
. 2018-07-05 14:04:48.648 Prompt (keyboard interactive, "SSH server: Password authentication", "Using keyboard-interactive authentication.", "Password: ")
. 2018-07-05 14:04:48.648 Using stored password.
. 2018-07-05 14:04:48.695 Access granted
. 2018-07-05 14:04:48.695 Opening session as main channel
. 2018-07-05 14:04:48.710 Opened main channel
. 2018-07-05 14:04:48.789 Started a shell/command
. 2018-07-05 14:04:48.789 --------------------------------------------------------------------------
. 2018-07-05 14:04:48.789 Using SFTP protocol.
. 2018-07-05 14:04:48.789 Doing startup conversation with host.
> 2018-07-05 14:04:48.789 Type: SSH_FXP_INIT, Size: 5, Number: -1
< 2018-07-05 14:04:48.804 Type: SSH_FXP_VERSION, Size: 5, Number: -1
. 2018-07-05 14:04:48.804 SFTP version 3 negotiated.
. 2018-07-05 14:04:48.804 We believe the server has signed timestamps bug
. 2018-07-05 14:04:48.804 We will use UTF-8 strings until server sends an invalid UTF-8 string as with SFTP version 3 and older UTF-8 string are not mandatory
. 2018-07-05 14:04:48.804 Getting current directory name.
. 2018-07-05 14:04:48.804 Getting real path for '.'
> 2018-07-05 14:04:48.804 Type: SSH_FXP_REALPATH, Size: 10, Number: 16
< 2018-07-05 14:04:48.820 Type: SSH_FXP_NAME, Size: 78, Number: 16
. 2018-07-05 14:04:48.820 Real path is '/'
. 2018-07-05 14:04:48.820 Startup conversation with host finished.
< 2018-07-05 14:04:48.820 Script: Active session: [1] Regeneron_QA@ftp.physiciansworld.com
> 2018-07-05 14:04:48.898 Script: pwd
< 2018-07-05 14:04:48.898 Script: /
> 2018-07-05 14:04:49.039 Script: put -nopermissions -nopreservetime -transfer="binary" -- "C:\\Florence\\Test\\Temp.txt" "\Inbound\"
. 2018-07-05 14:04:49.039 Copying 1 files/directories to remote directory "/"
. 2018-07-05 14:04:49.039 PrTime: No; PrRO: No; Rght: rw-r--r--; PrR: No (No); FnCs: N; RIC: 0100; Resume: S (102400); CalcS: No; Mask: \Inbound\
. 2018-07-05 14:04:49.039 TM: B; ClAr: No; RemEOF: No; RemBOM: No; CPS: 0; NewerOnly: No; InclM: ; ResumeL: 0
. 2018-07-05 14:04:49.039 AscM: *.*html; *.htm; *.txt; *.php; *.php3; *.cgi; *.c; *.cpp; *.h; *.pas; *.bas; *.tex; *.pl; *.js; .htaccess; *.xtml; *.css; *.cfg; *.ini; *.sh; *.xml
. 2018-07-05 14:04:49.039 File: 'C:\\Florence\\Test\\Temp.txt' [2018-07-05T17:59:03.899Z] [11]
. 2018-07-05 14:04:49.039 Copying "C:\\Florence\\Test\\Temp.txt" to remote directory started.
. 2018-07-05 14:04:49.039 Binary transfer mode selected.
. 2018-07-05 14:04:49.039 Opening remote file.
> 2018-07-05 14:04:49.039 Type: SSH_FXP_OPEN, Size: 33, Number: 259
. 2018-07-05 14:04:49.117 Server sent command exit status 0
. 2018-07-05 14:04:49.117 Disconnected: All channels closed
. 2018-07-05 14:04:49.117 Connection was lost, asking what to do.
. 2018-07-05 14:04:49.132 Asking user:
. 2018-07-05 14:04:49.132 Connection has been unexpectedly closed. Server sent command exit status 0. ()
< 2018-07-05 14:04:49.132 Script: Connection has been unexpectedly closed. Server sent command exit status 0.
< 2018-07-05 14:04:
54.210 Script: Searching for host...
. 2018-07-05 14:04:54.210 Looking up host "ftp.physiciansworld.com"
. 2018-07-05 14:04:54.210 Connecting to 75.101.155.12 port 22
< 2018-07-05 14:04:54.226 Script: Connecting to host...
