WinScp Component or Library for delphi
nachi
wittenberge
Hallo,
i have see a lot of examples and librarys for .Net, C# and..
but i want ask if you have a libray can i use it to make Files Transfer over SFTP in delphi 10.1 or dalphi 7
thx
Re: WinScp Component or Library for delphi
I believe that Delphi now supports .NET, doesn't it? So you can use WinSCP .NET assembly.
Or, if a direct .NET is not possible, you can still use it as a COM library.
nachi
wittenberge
thx. i make it with process, and it is amazing
