Server Key Mismatch
InteXX
Fairbanks, Alaska
Server Key Mismatch
I have found that the automation module returns a different MD5 key than does the UI, using the Session.ScanFingerprint() method. In this case, the key returned from the SDK is the correct one.
SDK: 78:b7:60:ec:c9:51:7b:a8:a5:55:2e:76:ab:08:c2:89
UI: c4:38:c2:a9:c5:87:16:d7:27:67:1d:85:e8:37:d9:9c
1. I'm using v5.13.3
2. I don't believe this was occurring under v5.11.2 (but I could be mistaken)
3. I'm running my app on Win10; the server is Ubuntu Server running in a VM
4. SFTP
5. Automation/GUI (both)
6. No error message (except in my app, due to a key mismatch)
7. N/A
8. N/A (problem manifests prior to session start)
9. Code:
Dim oSessionOptions As New SessionOptions
oSessionOptions.Protocol = Protocol.Sftp,
oSessionOptions.HostName = Utils.Registry.ImportHostName,
oSessionOptions.UserName = Utils.Registry.ImportUsername,
oSessionOptions.Password = ImportPassword.Decrypt(Utils.Entropy)
Using oSession As New Session
  Return oSession.ScanFingerprint(oSessionOptions, "MD5")
End Using
[img][/img]
Description: This is the key returned by the UI
Well, I expected a log file from ScanFingerprint method.
What I can tell you so far, based on these logs, is that the server has multiple host keys.
.NET uses an RSA host key, because you've told it so (SshHostKeyFingerprint = "ssh-rsa ...").
While GUI defaults to an ECDSA/nistp256, because it's a more secure host key than RSA.
InteXX
Fairbanks, Alaska
Is there a way to force the older MD5 in the GUI? I've poked through the Advanced Site Settings dialog, but nothing's jumping right out at me.
I need this because I'm supporting a customer who's still on MD5. The multi-key server at my site is an Ubuntu Server running in my Dev environment, but the customer requirement in Prod ripples down to Dev, both GUI and Automation.
It's not about MD5. Note that even your GUI dialog shows both MD5 and SHA-1 for the same host key. It's about host key algorithm.
There's no option to configure preferred algorithm in WinSCP GUI.
But you can use Hostkey raw setting:
https://winscp.net/eng/docs/rawsettings
Or you can use PuTTY, which allows setting preferred algorithm and import PuTTY settings to WinSCP.
https://the.earth.li/~sgtatham/putty/latest/htmldoc/Chapter4.html#config-ssh-hostkey
https://winscp.net/eng/docs/ui_import
See also https://stackoverflow.com/q/44786663/850848
