moved from one machine to another - importing correctly
openSuseman
hello dear experts i moved from one machine to another
and now the protocoll says - cant find the (credential) files on -- path (the old_machine/c/etc/etx
note - even if i have entered a new protocoll file - (with the upload of new credentials ) i get this annoying message...
why this happens.
how to fix that correctly
openSuseman
Fehler:
kann protokolldatei "C:\Users\my_old_computer\path_to_file" nicht öffnen.
System Error Code: 2
Das System kann die angeegebenen Daten nicht finden.
translated -
could not find the protocoll-file...
we have several occurences of the path in the ini file
we can change it (that is the path )= in the ini-file of - perhaps somewhere at the winSCP-Client itself
PuttyPath=
LogFileName=
ActionsLogFileName=
[Configuration\History\PuttyPath] 0=
[Configuration\Interface\Explorer] ToolbarsLayout=
UserName=vhost
PublicKeyFile=
LocalDirectory=
RemoteDirectory=/
well this is somewhat interesting
in the documentation we can read:
Transferring the Configuration
To transfer your configuration to another computer/location, export the configuration to an INI file and then import the file on the another computer/location.
Registry Key
well - that means that we only have to take the file and port it over...
is this true
