Task Scheduler - GET and MOVE
whgragso
I have a script setup to get files from my SFTP and place them on a local folder. Instead of deleting the file after I get the file, I would like to move it to a folder on my SFTP. The get function is working but the mv is not. Any ideas?
open sftp://********************/ -hostkey="ssh-rsa 2048 *******************=" -privatekey="*************************"
cd /upload
lcd C:\TEST
get file-int-*.mp
mv file-int-*.mp /old
Re: Task Scheduler - GET and MOVE
It should be mv file-int-*.mp /old/
Though note that your script is not transactionally safe. If a new file appears after get starts, but before mv, it won't be downloaded, but will be moved.
For a translatioanlly safe solution see https://stackoverflow.com/q/48311614/850848
