login faild
alvabress
login faild
Hi all,
I use the connection string
winscp.exe ftp://user:passw@host/
to open a connection on an ftp server because i need to download all the file in the root folder.
I got the following message:
"Connection to host...
Access denied." and a field to insert the corrected password
If i cupy and paste the same password i can open the client...
The complete script i would like to execute is:
cd C:\Program Files (x86)\WinSCP
get dummy.txt C:\
Where i'm wrong? Thanks
Re: login faild
Your password probably contains some special characters that need to be URL-encoded.
See https://winscp.net/eng/docs/session_url#special
It that does not help, please attach a full session log file showing the problem (using the latest version of WinSCP).
cluisvera
Ecuador
Re: login faild
Me sale este error como puedo solucionarlo:
C:\Dobra7>"C:\Program Files (x86)\WinSCP\winscp.com" /script=winscp-upload-script.txt
batch abort
confirm off
Buscando servidor...
Conectando al servidor...
Autentificando...
Usando el nombre de usuario "xxxxxx".
Autentificando con el password pre-entrado
Autentificado.
Iniciando la sesión...
Leyendo directorio remoto...
Sesión iniciada.
Sesión activa: [1] xxxx@xx.xx.xxx.xx
Nuevo documento de texto. | 0 B | 0,0 KiB/s | binary | 0%
La conexión ha sido cerrada inesperadamente. El servidor ha enviado el estado 0 como retorno del comando
A(b)ortar, (V)olver a conectar (0 s): Volver a conectar
Autentificando...
Usando el nombre de usuario "xxxx".
Autentificado.
Sesión iniciada.
A(b)ortar, (V)olver a conectar (5 s): Volver a conectar
Acceso a memoria no válido
Por favor, ayúdanos a mejorar WinSCP informando el error en el foro de soporte WinSCP.
A(b)ortar, (V)olver a conectar (2 s): Volver a conectar
Invalid pointer operation
Reply with quote E-mail
