Error code: 2 - Error message from server: No such file
                hello dear all.
after moving the config-files from one Notebook to another Notebook i have gotten an error_
system Error: error 2
Während des Protokollierens ist ein Fehler aufgetreten.
Das Protokollieren wurde abgeschaltet.
Kann Protokolldatei "c\users\myold-notebook\...nicht öffnen.
translated:
during the protocoll an error occurred: the protocol-process was interrupted and switched off
cannot open the Protocolfile "c\users\myold-notebook\...
the system cannot find the reffered file.
well i guess that i have missed something. If i look at the paths in the winSCP - there lots of path are included
but - i guess that this would not help if i correct them all.
i guess that a simple correction ofthe paths would not help...
what do i muss - what do i need to do
translated:
PuttyPath=
LogFileName=
ActionsLogFileName=
[Configuration\History\PuttyPath] 0=
[Configuration\Interface\Explorer] ToolbarsLayout=
UserName=vhost
PublicKeyFile=
LocalDirectory=
RemoteDirectory=/
