Custom command after transfer from GUI
tobkum
Germany
Hey there!
I have to upload different files from all over the place on a daily basis, so I'm using the WinSCP GUI for dragging-and-dropping of those files. So far so good.
What would REALLY help me is the option to not only shutdown PC, sleep PC or disconnect session after the queue is finished, but an option to execute a custom command. This way I'd be able to send a notification to my mobile phone via a python script for example. I know this might be doable when using the command line, but I need a solution from the GUI in my use-case.
Or did I just miss something and this is already available?
Cheers & thanks,
Tobi
