Moving local files to different location with timestamp after successful upload
Thanks to WinScp team providing few scripts.
I am new to power shell request help how to put timestamp while moving file to another directory after successful upload.
example
Localpathfile : E:\ABC\Zip_Source\testfile.xml.zip.p7
backupPath = "E:\ABC\Backup\testfile.xml.zip.p7_DDMMYYYY_HHMMSS
I giving below code here from winscp sample scripts.Script from internet
example
# Upload Files to FTP and move source files to archive param ( $localPath = "E:\ABC\Zip_Source\*.p7", $remotePath = "/home/user/", $backupPath = "E:\ABC\Backup\" ) try { # Load WinSCP .NET assembly Add-Type -Path "WinSCPnet.dll" # Setup session options $sessionOptions = New-Object WinSCP.SessionOptions -Property @{ Protocol = [WinSCP.Protocol]::Sftp HostName = "example.com" UserName = "user" Password = "mypassword" SshHostKeyFingerprint = "ssh-rsa 2048 xx:xx:xx:xx:xx:xx:xx:xx:xx:xx:xx:xx:xx:xx:xx:xx" } $session = New-Object WinSCP.Session try { # Connect $session.Open($sessionOptions) # Upload files, collect results $transferResult = $session.PutFiles($localPath, $remotePath) # Iterate over every transfer foreach ($transfer in $transferResult.Transfers) { # Success or error? if ($transfer.Error -eq $Null) { Write-Host "Upload of $($transfer.FileName) succeeded, moving to backup" # Upload succeeded, move source file to backup Move-Item $transfer.FileName $backupPath } else { Write-Host "Upload of $($transfer.FileName) failed: $($transfer.Error.Message)" } } } finally {
