winscp.com not found
thowi84
Hi all together,
I want to transfer a file via sftp to my ftp server.
Therefor I built a batch file with the following line:
winscp.com /ini=nul /script="C:\Users\Administrator\Documents\Austausch_\Automatisierung-Batchfiles\Export-Import-Dateien\realangebote.ftp"
After starting the batch file, the command line tool shows the following error:
https://www.dropbox.com/s/e28z0jvun9ojwu6/error2.jpg?dl=0
So it looks like that the program cannot be found. Of course I installed WinSCP from the download section. I can start the Gui, no problem. But whatsoever the winscp.com via batch file cannot be started...
Where is my mistake?
Thank you for your help!
