Rename Remote file
Pathak79
India
Rename Remote file
Kindly let me know the script to rename the remote file like i have uploaded the file (Filename.txt) into server after successfully upload u wanted to rename it with Filename.doc.
Thanks in advance.
Reply with quote E-mail
Re: Rename Remote file
You can upload a file to a different filename directly like:
put C:\local\path\Filename.txt /remote/path/Filename.doc
