Task in scheduler doesn't work properly
thies
my task in Windows Task scheduler (Windows Version 1803) doesn't cannot connect to the server in the first try but works fine afterwards.
In both cases the task is executed by a service account and none of the settings are changed. In the first try I get the error
" Connection has been unexpectedly closed. Server sent command exit status 0. Authentication log (see session log for details): Using username "USERNAME". Further authentication required
Authentication failed."
I already created two log files (one for the fail, one for the working run) and attached them (marked as private). Unfortunately I don't have access to the server.
I'm using this code in powershell:
# Setup session options
                    HostName = $customer.FTPSettings.server;
                    Portnumber = $customer.FTPSettings.portnumber;
                    UserName = $customer.FTPSettings.user;
                    SecurePassword = ConvertTo-SecureString $customer.FTPSettings.password -Key $key;
                    SshHostKeyFingerprint = $customer.FTPSettings.SSHKey;}
                try
                # Connect
                $transferOptions.TransferMode = [WinSCP.TransferMode]::Automatic;
                $transferOptions.PreserveTimestamp = $false;
                $sychronisationResult = $session.GetFiles(
                    $downloadpath,
                    $repositorydirProgress,
                    $false,
                    $transferOptions
Thanks for your help.[/code]
  • FTPLog.log (18.99 KB, Private file)
Re: Task in scheduler doesn't work properly
Please start by contacting the server administrator to get some explanation why the authentication is failing.
