Keep Remote Directory up to Date seperate thread (non blocking)
reged
Hi, I use the Keep Remote Directory up to Date feature very often but find myself frustrated that it blocks the main program thread.
If I want to do anything else on the server (often this is the case), I have to stop remote update, do what I want to do and then turn it back on (or forget and wonder why my site isn't updating).
Please could you push this feature onto a seperate thread so that I can continue using WinSCP whilst simultaneously having a directory automaticaly kept up to date?
Many thanks for reading
Re: Keep Remote Directory up to Date seperate thread (non blocking)
The next version (5.14) will allow you to start “Keep remote directory up to date” in a new window (new process).
I'm sending you an email with a development version of WinSCP to the address you have used to register on this forum. There's "Start in New Window" command in "Start" button dropdown menu.
I appreciate any feedback.
reged
Hi Martin,
At first glance, this looks like exactly what I wanted. Thank you for the very fast response. I'll trial it for a few days and let you know if I encounter any problems or have any additional thoughts.
Reged.
