WinSCP "freeze" after few seconds after connection
Waruwaru
Deutschland
Winscp 5.13.4 on Windows 10 (1803 Build 17134.254) with SFTP. Thats very difficult to describe.
I connect to my server and can change folder and after few seconds every click in winscp make only "ping"-sound. The same sound, when a messagebox have the focus and you must to confirm this messagebox before you get back to the app. But here is no visible messagebox. That happen for me, very often; I think 25% every time I start winscp. I use winscp for years and this problem is new maybe in the last one or two versions? When its happen, than only few seconds after connect to server.
Waruwaru
Deutschland
Thanks. Unfortunately that not helped. :)
UPDATE:
I start winscp and connected. Now I navigate to any folder, its open, than to another folder, is open, another folder... only few seconds... and "ping"-sound. winscp is not workable and must kill with task manager.
digitaltoast
Hi there;
Exactly the same setup as the OP, having the same problem.
Can you please send me the updated version? I'm using portable apps, but I don't think that makes any difference - version is identical, as are the symptoms.
Thank you!
Sent.
pjuniororeons
Also having the same problem
Hi, I am also having the same problem, when trying to upload some files using winscp in a console application built in .net c# some files freeze and do not complete the transfer.
Could you send me the debug version to test?
Re: Also having the same problem
This looks like a completely different problem than what this topic is about.
Please start a new thread and post a session log file.
nikhil1328
India
Facing the same issue. Winscp hangs after establishing the connection.
Re: Facing the same issue. Winscp hangs after establishing the connection.
tt.boy@...
I have same problem, can you send me the debug version?
I used 5.57.9 but does not work. Filezlla also does not work.
Re: I have same problem, can you send me the debug version?
Sent.
