Can't Create New File
GGOLE
Hi
Whenever I try to create a new file from FTP, it will open up the external editor (sublime text 3) and then when I try to save it says:
Unable to save: C:/user/home/temp/file.php
Error: The System cannot find the path specified.
Why is it trying to save it in the temp directory and not on the server?
Re: Can't Create New File
Sublime has to save the file to a temporary folder, for WinSCP to pick it up from there to upload.
Anyway, if you edit an existing file, can you save it/upload it?
If you right click the file and click Edit from WinSCP it opens in Sublime. But if you try to save it, it gives that error.
hi
Can't save file in Sublime
Hi
Whenever I try to save file after edit file from WINSCP, error pops up and says:
Re: Can't save file in Sublime
That's the same question as above. If you want our help, then please post your editor settings, as I have asked above.
