Force TLS 1.0 via Scripting
IPolix
I'm having trouble passing files from one machine to another in the same network and I can't activate TLS 1.1 / 1.2 in the machine that recives the files. How can I force the script to communicate via TLS 1.0?
Thanks!
Pol
IPolix
Re: Force TLS 1.0 via Scripting
Yes, I used the argument you said and it worked perfectly. Thank you very much.
I'm currently running the version 5.13.4 (Build 8731).
