"Server sent passive reply with unroutable address 127.0.0.1, using host address instead."
thiagoaoshi
Brasil
Don't connect FTP!!
Print message:
instead.
I tried to use passive mode (-passive=on), but without success. :(
Can someone help me in this case?
Re: "Server sent passive reply with unroutable address 127.0.0.1, using host address instead."
shuvoc279
India
FTP failing when using load balancer instead of hostname
I am using loadbalancer IP for FTP instead of direct FTP server IP. In the log, I can see below error.
Server sent passive reply with unroutable address XX.XX.XX.XX, using host address instead.
Where XX.XX.XX.XX is my direct FTP server IP.
Not able to figure out what is happening here. Why it is saying unroutable address when load balancer is routing to direct FTP server IP.
