One line to change password "WinSCP.com /key gen key.ppk /changepassphrase"
cmoran
Hi all, I am trying to change the passphrase for a .ppk file.
I can change the password using CMD as Administrator by running the command "WinSCP.com /key gen key.ppk /changepassphrase", then entering the password twice.
I wish to do the above with a script, is there a way to set the password in one line?
I have tried a few things similar to below in a batch script but had no luck.
Password
Password
Can anyone point me in the right direction?
#Please not i had to split key gen as it is caught by the spam filter
Re: One line to change password "WinSCP.com /key gen key.ppk /changepassphrase"
You can use this (undocumented) syntax:
WinSCP.com /keygen key.ppk /passphrase=old /changepassphrase=new
