Permission denied using MoveFile method
johnmcp
Ireland
I have created a simple Powershell script to move files from one location to another on the same server.
This is my code:
        #$files = $session.ListDirectory($remotePath)
        # Iterate over every transfer
        $fileInfos =
            $session.EnumerateRemoteFiles(
                $fromPath,
                $Null,
                [WinSCP.EnumerationOptions]::EnumerateDirectories -bor
                    [WinSCP.EnumerationOptions]::AllDirectories)
        foreach ($fileInfo in $fileInfos)
            if ($fileInfo.IsDirectory)
                #TODO
            else
                $session.MoveFile($fileInfo, $toPath)
On executing the code I get a Permission denied error.
I have verified the user has the required permissions by performing the same move operation from the WinSCP GUI, so I don't know why I am getting this error when using the script.
Grateful if someone can provide advice on this.
johnmcp
Ireland
The documentation also says this:
The name must be included or the target page has to end with a slash
I have set the value of $toPath to this:
$toPath = "/DataWarehouse/Dev/"
Noting that the trailing slash is included.
The exact error description is:
"Error moving file 'AMPS_Transactions.xlsx' to '/DataWarehouse/Dev/AMPS_Tr
ansactions.xlsx'.
Which would indicate to me that the $toPath variable is correct.[/quote]
So that's good.
I can see the real problem now:
You do not pass a path to the source file. You pass $fileInfo object (what converts to a mere filename, by an implicit call to .ToString).
Use $fileInfo.FullName.
