Search in Login Window by Site name
HonyZahy
Prague
I have more than 50 sites and I'm not good looking for it. I suggest allowing search by name, for example as in Putty.
Re: Search in Login Window by Site name
How can you search for name in PuTTY? Do you mean by typing the first letter?
In WinSCP, you can do the same. Actually in WinSCP, you can even type multiple leading letters. Or even any part of a hostname (not only leading part).
See https://winscp.net/eng/docs/ui_login#management
(look for "incremental search").
HonyZahy
Prague
Hi Martin,
thank for reply.
I have the exactly site name in Clipboard. Putty hasnt a direct search, but it isnt a problem to insert a site name directly from the Clipboard.
Search site by typing part of its name is good feature. So, insert from Clipboard isnt possible.
