Powershell SynchronizationMode speed limit not work
I have follow the below link to setup Synchronization by powershell and try to limit the speed. I have enabled the transferOptions object but it not work.....
https://winscp.net/eng/docs/library_session_synchronizedirectories#powershell
try
HostName = "example.com"
UserName = "user"
Password = "mypassword"
SshHostKeyFingerprint = "ssh-rsa 2048 xx:xx:xx:xx:xx:xx:xx:xx:xx:xx:xx:xx:xx:xx:xx:xx"
try
# Will continuously report progress of synchronization
$session.add_FileTransferred( { FileTransferred($_) } )
# Connect
$transferOptions.SpeedLimit = 10
# Synchronize files
$synchronizationResult = $session.SynchronizeDirectories(
[WinSCP.SynchronizationMode]::Remote, "d:\www", "/home/martin/public_html", $False, $transferOptions)
# Throw on any error
$synchronizationResult.Check()
finally
# Disconnect, clean up
$session.Dispose()
exit 0
try
UserName = "user"
try
# Connect
# Synchronize files
finally
$session.Dispose()
exit 0
