Session.Open() timeout variable
matt.baker
Is there a user configurable variable for the timeout of the Session.Open?
I've tried setting Session.Timeout to 1000 ms, but it seems to be taking ~22 seconds to time out on an unreachable host regardless.
matt.baker
Thanks. I tried this as well, using the SessionOptions.TimeoutInMilliseconds and SessionOptions.Timeout, but it's not having any effect on the open timeout.
matt.baker
Thanks for looking into this Martin.
For a workaround I just attempt to open a connection to the host using a raw TCP connection and then just check for the SSH ID string within a certain time.
