Unable to synchronize remote folder with constantly changing files
ttblum
Cleveland, OH
I'm trying to mirror the contents of a remote SFTP folder to a local folder (I need a local copy of the remote folder). The contents of the files in the remote folder are constantly changing (although the number of files and filenames stay the same).
WinSCP seems to be generating errors when it realizes the files in the remote folder have changed while it is synchronizing.
Is it possible to synchronize a remote folder that has files that are constantly changing?
Re: Unable to synchronize remote folder with constantly changing files
