All sites have disappeared
mikeyott
Australia
Yesterday, for whatever reason, my Windows 10 PC crashed and I was forced to reboot. Now when I open WinSCP all my sites have disappeared. Is there a way I can get them back? This is quite an annoyance, given I had close to 60 sites.
mikeyott
Australia
Re: All sites have disappeared
Did you use registry or INI file to store WinSCP settings?
I didn't even know there was an option. I'm assuming that as I add sites in WinSCP, they get stored in an INI file somewhere by default, and that now it's either not loading or it's missing.
Do you have WinSCP installed? If you use the standard installer, then it should use registry by default.
