Recently Sites List
BG1956
UK
Recently Sites List
Is it possible to reset the list that appears on the Win 8.1 Start Menu (or delete old and unwanted entries from the list)?
Re: Recently Sites List
When you right-click the entry, there's "Remove from this list" command - It's a Windows feature, working for any application. It has nothing to do with WinSCP itself.
BG1956
UK
I've done this but the next time I turn on my PC, the entries are all back. I've been through the WinSCP section of the Windows Registry and there seems to be nothing obvious that allows control of this.
Can you document that using step by step instructions and maybe few screenshots?
Ntb, WinSCP jumplist is stored in JumpList value of HKCU\Software\Martin Prikryl\WinSCP 2\Configuration registry key.
