Automating remote directory sync
nccool2104
Mauritius
Hi
am new to WINSCP but found out that it does great things and also match our requirements.
however we need the app to start as a service and automatically start a saved session with the "keeping remote directory up to date" started as well.
its working perfect but if we log of the user profile all the tasks will stop.
can someone help us in achieving this.
Thanks in advance.
Re: Automating remote directory sync
