Option for "Session/Repeat Key Exchange"
fentog
I use different tools that calls to WinSCP for opening SFTP sessions. The integration is great, and works as expected.
However, in some cases I like to "modify" the running connection of WinSCP. For example, to enable COMPRESSION, or (less relevant) to change the algorithm.
So, I request for an option for "Reconnect" changing some of the current connection parameters.
Does this sound good to you?
fentog
OR some other option:
For the command "Session/Duplicate session" hold the key <CTRL> or <ALT> for opening the connection window with all the parameters of the session inserted with the option to edit some of them.
You agree?
OscarM
I see this interesting. I use the Right menu to open several sessions. So I think an option to change some of the connection parameters (like compression) can be very useful.
I'd like to see it implemented.
