Precess Winscp when runs from batch freezes
commandline parameters
WinSCP.exe" /xmllog="C:\Users\xxx\AppData\Local\Temp\wscp25F8.034B51FA.tmp" /xmlgroups /nointeractiveinput /dotnet=571 /ini=nul /console /consoleinstance=_9720_55849617_658
Re: Precess Winscp when runs from batch freezes
