Proof of concept to run the below winscp script on my local dev server
clyded
Hi All,
I'm making a proof of concept to run the below winscp script on my local dev server. Could you please help?
Original script
option batch abort
option confirm Off
open sftp://username:password@server -hostkey="ssh-rsa 2048 mac-address"
synchronize local local-directory remote-directory -filemask="|*.*_"
Proposed
I need to run the script on my local dev server tranferring file from one folder to another (in the same server).
Question
How do I modify the open command to meet this requirement?
I tried removing the open command from the script but that does nothing.
Clyde
Re: Proof of concept to run the below winscp script on my local dev server
Do you want WinSCP to synchronize files between two local folders? - i.e. no connection to any server.
WinSCP cannot do that. You would have to install/configure SFTP/FTP server on the local machine.
clyded
Thanks, Martin.
Apologies, I'm a bit new to this - so, just to confirm:
- I should be able to follow this article: https://winscp.net/eng/docs/guide_windows_ftps_server to setup IIS on my Windows server and then open a connection to the same server?
- And then the local directory transfer would work?
Clyde
