Powershell Multiple FileMasks and ModifiedTime criteria
kilde
I have a script which works when $mask = "*.csv". It retrieves what it should. However, I would like to apply another mask, namely files modified within last 3 hours.
I've tried $mask = "*.csv | *>3H" which fails, and also $mask = "*>3H" which fails too.
If necessary, I can do without my file extention criteria.
I hope someone can help me implement the modifiedTime mask.
My script is:
try
# Load WinSCP .NET assembly
Add-Type -Path "C:\Program Files (x86)\WinSCP\WinSCPnet.dll"
#Add-Type -Path "WinSCPnet.dll"
# Setup session options
Protocol = [WinSCP.Protocol]::ftp
HostName = "ftp.host.com"
UserName = "testuser"
Password = "testpass"
try
# Connect
Write-Host "Session opened at $(Get-Date)."
$remotePath = "/folder/"
$localPath = "C:\data"
$mask = "*.csv"
$files = $session.EnumerateRemoteFiles(
$remotePath, $mask, [WinSCP.EnumerationOptions]::AllDirectories)
foreach ($fileInfo in $files)
Write-Host "Downloading $($fileInfo.FullName) ..."
$filePath = [WinSCP.RemotePath]::EscapeFileMask($fileInfo.FullName)
$session.GetFiles($filePath, $localPath + "\*").Check()
Write-Host "Download of $($fileInfo.FullName) succeeded"
finally
# Disconnect, clean up
$session.Dispose()
Write-Host "Session closed at $(Get-Date)."
exit 0
catch
exit 1
kilde
Denmark
If-solution
So, I've implemented an if statement in the loop, checking the files timestamps, but I'd hope that a mask could execute much faster.
For those looking for a solution, here is my current implementation:
try
$cuttime = $(get-date).addminutes(-30)
try
# Connect
$mask = "*.csv"
$remoteWriteTime = $fileInfo.LastWriteTime
if($remoteWriteTime -gt $cuttime)
#Write-Host "Downloading $($fileInfo.FullName) ..."
#Write-Host "Download of $($fileInfo.FullName) succeeded"
finally
$session.Dispose()
exit 0
catch
exit 1
Re: Powershell Multiple FileMasks and ModifiedTime criteria
Your solution is best possible (assuming that you really want to download all remote files - even those in subdirectories - to the same local directory - i.e. that you want to flatten a remote directory structure).
