Synchronize checklist-window as treeview checklist possible?
Waruwaru
Deutschland
For synchronize a single folder the view is fine, but here is not possible to exclude sub-folders from comparing, so after comparing(synchronize) the parent folder I must many files from sub-folders uncheck before starting transfer.
Its would be help, when the dialog is not a checkbox list, instead a treeview checkbox component, so that I can uncheck a folder, so all his files/folders uncheck too. So I need only one click for exclude a folder and his files and sub-folders.
What I mean with treeview checkbox list
Re: Synchronize checklist-window as treeview checklist possible?
That would be quite a change.
But I've added commands to check/uncheck all files that are in the same folder tree as selected file(s):
https://winscp.net/tracker/1705
The commands are in checklist context menu.
