Cannot disable updates
thierry
I am running WinSCP 5 with an INI file (no admin rights to access Windows registry). Each time it starts WinSCP:
1) Fails importing PuTTY sites,
2) Displays an "Error checking for application updates" box, with the message "SSL handshake failed : Secore connection truncated".
I tried to disable automatic update checking in the Preferences menu (set it to "Never"), but WinSCP checks anyway !
This is annoying as it takes forever (ok, about 30 seconds) before it concludes something went wrong and displays these error messages.
Is there a way I can actually prevent WinSCP / PuTTY from checking for updates?
Thank you for your help,
Thierry
Re: Cannot disable updates
Thierry
Switzerland
Hi Martin,
Thank you for your prompt answer. I've sent you an e-mail as requested.
Best,
Thierry
