Listing files matching wildcard
# Get list of matching files in the directory
$files =
$session.EnumerateRemoteFiles(
$remotePath, ($wildcard = Get-Content "test.txt"), [WinSCP.EnumerationOptions]::None)
# Any file matched?
if ($files.Count -gt 0)
foreach ($fileInfo in $files)
Write-Host $($fileInfo.Name) with size $($fileInfo.Length)
else
Write-Host "No files matching $wildcard found"
Is the bolded section not a valid option? I have 5 different lists that i need to us to download files from an FTP server. i have an option that is doing what i need but i'm not able to log the file it downloads like i can with this code i copied from your site.
When using my list like this it reads the two lines i have in the test file but says acts like there are no matches. if i remove the second line in the file it finds the matches of the single line item.
Re: Listing files matching wildcard
The mask parameter of Session.EnumerateRemoteFiles does not support multiple masks.
If you need multiple masks, do not use the mask parameter.
Instead, let Session.EnumerateRemoteFiles return all files and filter them programmatically, as you need.
trae*
United States
Could you give me an example of that ?
Would it be removing the $wildcard and then using a foreach with a where over and over for each file i need?
might help to add a little more detail on what the end result is.
i have a list of files that i need to download. filex*.dar ,fileb*.dar,filec*.dar etc and i would like each filename that is downloaded recorded. i have been able to get all the files downloaded but cant seem to do it to where it lists the actual filename being downloaded. only the wildcard name.
trae*
United States
wanted to add a little more detail to see if you can help me out .
so this is the code i am using that downloads the files to where i need them to go but wont list the individual file name downloaded only the wildcard. what can i do to change that?
try
$remotePath3 = "C:\folder\"
$lines2 = Get-Content "list.txt"
ForEach ($line in $lines2)
Write-Host "Downloading $line to C:\folder\ ..."
$session.GetFiles($line, $remotePath3).Check()
$dt = Get-Date
Add-Content $log "$dt : Downloading $($line) to C:\folder.."
i am using this over and over for each list that i need to sort through. sorry if none of this makes sense i can try to clarify more if needed.
Then it does not look like you need EnumerateRemoteFiles at all.
Use GetFiles, which supports multiple masks via TransferOptions.FileMask.
https://winscp.net/eng/docs/library_transferoptions#filemask
To log the downloaded files, iterate TransferOperationResult.Transfers.
See https://winscp.net/eng/docs/library_session_getfiles
If you want to log the files, as they are downloaded already, handle Session.FileTransferred event:
https://winscp.net/eng/docs/library_session_filetransferred
trae*
United States
thanks i will see if i can get it to work with those .
